s1 alternator brackets differant from a s2??
Old 12-02-2010, 06:09 PM
smitsturbo
smitsturbo's Avatar
Default s1 alternator brackets differant from a s2??
are s1 brackets differant from a s2 bracket as im offshore at the moment but im sure the adjuster arm is atatched o the block on my s1 engine where as the s2 adjuster is atatched to the bracket, can somebody confirm please before i go buying the wrong one
cheers
Old 12-02-2010, 07:24 PM
JesseT
JesseT's Avatar
I confirm. The mk4 bracket also makes the alternator sit lower than the mk3 mount.
Old 12-02-2010, 10:05 PM
gaz s1
gaz s1's Avatar
totally different as i found out when building my zvh, the s1 alternator, adjuster bolts straight into the block and the mount is in 2 peices as i found to my dismay as there is no hole in the side of the zetec block sh had to get a mk4 one out of a scrappy
Old 13-02-2010, 06:33 AM
smitsturbo
smitsturbo's Avatar
cheers
jonfoc
16
11-09-2018 05:35 PM
Sp3no
27-09-2015 07:23 PM
timsrs
22
24-09-2015 08:14 PM
DPDISXR4Ti
Ford Fiesta
21-09-2015 03:51 PM
jay030787
18-09-2015 04:38 PM
Quick Reply: s1 alternator brackets differant from a s2??
