Master Cylinders
Master Cylinders
Right i have the same problem as everyone else. I have a "25" Master Cylinder and its started weeping from the rear i know you cant get parts for them or the cylinders themselves, but what i need to know is can you use the 22 or 23 cylinders with the rst servo and also if they will be ok to use with my brake set-up, standard rears and cossie 4 pot fronts?
Not alot of choice unless you can source a good 2nd hand one (i bought one and it was fucked lol), a 22 or 23 will do the job but with a bit more pedal travel. I run standard rear and 4x4 calipers up front and still works ok with the 22mm cylinder.
Thats good to know anythings gotta be better than it leaking Im gonna have to get the servo powder coated now aswell though were the fluids gone down it.
