change ECU or not?
Old 09-01-2010, 10:36 PM
tasos77
rs turbo from Greece...
tasos77's Avatar
Default change ECU or not?
Here is my small problem...
my S2 has hearts and diamond ECU. My loom has the green plug for knock sensor. The problem is that my inlet hasn't knock sensor......
I need toi fit a chipped ecu, so because i want my car run propertly and i can't find a chipped without knock sensing i wondered if i can just fit a chipped ecu from a 90 spec S2, and just plug a knock sensor into the loom and nothing else..
Old 09-01-2010, 11:00 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Yes, wrap the knock sensor in some rag and tuck it out the way.
Old 09-01-2010, 11:10 PM
tasos77
tasos77's Avatar
thanks Karlos! All the chipped ecus on ebay from late S2 with knock sensing...Three months i'm loooking there i found only one from early S2 and i loose it..
Old 10-01-2010, 07:39 AM
tasos77
tasos77's Avatar
So if someone has a spare knock sensor and paypal account let me know it....
Old 11-01-2010, 04:41 AM
tasos77
tasos77's Avatar
up, and also can i use a Rs 1 ecu in my s2? The only difference is the knock sensor?
Old 11-01-2010, 03:16 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Yes you can use a S1 ECU in a S2.
Old 27-01-2010, 05:59 PM
tasos77
tasos77's Avatar
i plug a knock sensor today! I think the is going much better after 3500-4000 rpm. Can be true??
JK12
33
26-04-2021 12:09 PM
TPM961
15-01-2018 10:50 AM
DixieTheKid
14-09-2015 09:04 PM
tib2220
14-09-2015 12:33 PM
marky_g
12-09-2015 04:26 PM
Quick Reply: change ECU or not?
