Accralite 1.5mm oversize pistons
HI, I have a doubt about the pistons Accralite 1.5mm oversize pistons, this compression is 7.8:1 , which pressure turbo, maximum reliable, can I use with this compression ratio? my car has intercooler AIRTEC large, H-beam THS performance uk, OFAB management, cam piper t285 t2 and garrett t3 turbo.
And what power can I get? :DD: Regards |
well the turbo will max at around 20-21 psi so run it at "max" ad see what results you get. im asuming you are useing the correct chip for your spec?
Originally Posted by clarke5700
(Post 4493630)
© 2024 MH Sub I, LLC dba Internet Brands
