k and n panel filters do they work???
want 2 keep my turbo standars really needs a service might get the kandn panel filter do they work???
The best option for performance is the standard box with an K&N panel filter. The XR3i and RST filter fit eachother.
yup they work, better than cones :D
got k&n panel on mine plus my bro has the same on his 2i make a significant differeance plus dont need periodic replacement so you cant go wrong :top:
yes i heard that the element, drilled airbox conbination works better than 57i's etc.... on rs's. Soy have you still got your car? i read in performance ford that you were breaking it :( :cry: ....fucking sweet car matey :top:
panel filter it is then cheers guys
maybee when you sit in traffic and get massive heat soak then the standard air box is better but when your out on the open road flying along I have seen better ACT temps from the cone filter !
Duncan |
As above. :top:
hmmmm ur makin it hard nw due fink i can fit the 57i into the airbox 4 best of both worlds!!! :blabla: :blabla:
if u modify the airbox properly i cant c why u wont get good act's...
https://img.photobucket.com/albums/0...r/DSCF0037.jpg Dont drill it, waste of time. . do as above. Fact - cones are wank. . . |
nope, FACT - been proven infront of my own eyes many times ;) im not telling you to change it. . . :p
Well said Dave
Cone filters are a total waste of money, i have a standard very dirty ford panel filter in a airbox identical to Daves(vroooomptssssh) and im getting 205.1 @ the wheels. You trying to tell me i would get more power putting on an exposed filter that sits about 2 feet from a roasting hot turbo :cry: :cry: :cry: :cry: :cry: :cry: :cry: |
Originally Posted by T28 RST
Well said Dave
Cone filters are a total waste of money, i have a standard very dirty ford panel filter in a airbox identical to Daves(vroooomptssssh) and im getting 205.1 @ the wheels. You trying to tell me i would get more power putting on an exposed filter that sits about 2 feet from a roasting hot turbo :cry: :cry: :cry: :cry: :cry: :cry: :cry: only time heat from turbo will get to it is standing still! unless suddenly heat rises to the left????? :? :? :? |
:cry: we could all argue about this all day long but at the end of the day its personel preference ! I have personally seen better ACT temps from using my cone filter so I think I'll stick with that !
© 2024 MH Sub I, LLC dba Internet Brands
