confirm a few aux hoses please guys
Old 25-08-2009, 01:24 PM
stevenebm
post whore
stevenebm's Avatar
Default confirm a few aux hoses please guys
wanting to double check for my s1 aux hoses.the one coming from water pump up to t peice.does one go to the top matrix inlet and the other from this t peice to original oil cooler and from other side of oil cooler to inlet manifold?also i seem to have some connections at my aux air device which looks like it goes straight through it.what is this??
Old 25-08-2009, 03:29 PM
jodyhoare
jodyhoare's Avatar
hi mate, you aux water piping is exactly how how you described, as for the aux air device i dont get what you mean mate?
Old 25-08-2009, 03:48 PM
stevenebm
post whore
stevenebm's Avatar
just had a better look mate and its above the aux air sorry.its a small angled bit of water pipe.just looks like a connector.im thinking its meant to go from the t peice through the connector and then to oil cooler.the hoses ive got seem to all fit like that so as long as the above way i said is correct then it should be ok.cheers again mate
Old 25-08-2009, 04:49 PM
jodyhoare
jodyhoare's Avatar
yeah from that t-piece u got to the heater matrix and to a pipe bolted to the bottom left side of the inlet then the other side of that pipe goes to the oil filter housing. then the other side of the housing goes to the inlet.
JK12
33
26-04-2021 12:09 PM
griffo69
26-09-2015 04:23 PM
Mk5brown
09-09-2015 12:52 PM
Rizlablue
06-09-2015 09:58 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: confirm a few aux hoses please guys
