Zetec Turbo pinking..
i have a fiesta zetec turbo which is running megasquirt v3, ive just checked the timming at idle and its 30 degrees advanced, does any one know what it should be set at, cheers.
engine spec (let pistons so i was told by seller) but i think there xe pistons, head skim 13 thou and block skim 7 thou (maybe over skimmed i dont know?) standard cams, adjustable pullys set at 0 degrees, uprated valve springs, stg3 t3 running aprox 10 psi focus rs headgasket and spark plugs..
im in the channel islands, thats why its diffult to find a tuner, does any one know if theres and megasquirt tuners down south? also does and one know what the cr will be with my spec engine, xe pistons(they were meant to be let ones but im now told there not) head skim 13 thou, block skim 7 thou with focus rs headgasket?
ive just ordered a rs232 to usb cable ( i think thats the one lol) to connect ecu to laptop, so im gana try and set it up, the pervoius owner had maped the car to run 9.1 cr which was a standard Zetec with a 1 mm decomp plate, and one mondeo head gasket, and it ran fine till the bottom end went, so i then rebuilt the engine with the spec listed adove and now its pinking under hard acceleration..
does and one know what cr my engine is? head skim 13 thou, block 7 thou skim, focus rs headgasket and xe pistons, any help would be great, would it be more or less compression than pervious, which was 9.1 cr, standard zetec with 1mm decomp plate and mondeo headgasket, cheers...
Bodger of Blackburn
i can only guess, but xe peistons usually make around 8.4:1 cr, maybe a little more given the block being decked and head skimmed a little.
if anything on the same map as before, you chould be getting less det, but of course the fuelling will be way off now, so running lean probably.
before doing anything else, get a wideband setup and get the mapping sorted.
Is it a blacktop or silvertop?
its a silver top engine, im going to get it set up on the laptop and see whats what, its strange how it was fine, and since rebuild its pinking/detonating at onlt 10 psi...? maybe the compression is higher now..?
just worked out the CR 9.44:1 it was mapped to 9.1:1 that is probley the cause. of the pinking.. does anyone know if these head gaskets are any good http://www.pumaspeed.co.uk/showdetails.php?id=470 im thinking of using the thicker head gasket to lower the comperssion...
