MFI ---> EFI How much £££ and where?
Old 16-08-2009, 07:59 AM
liddon21
liddon21's Avatar
Default MFI ---> EFI How much £££ and where?
Hi all,
Pretty much as the title states really, How much should i be expecting to pay for the conversion and can anybody reccomend where i should go.
I'm based in Herts/Essex area.
I'm not the most mecahincly minded so am not going to try myself
Old 16-08-2009, 08:16 AM
kidsRS
"Ill check the stock"
kidsRS's Avatar
I was quoted 1500pounds to convert my s1 to run efi inlet manifold and omex management. That was at mikeanics motorsport up my area.
Old 16-08-2009, 09:41 PM
morph
morph's Avatar
can get it done for about 900 all in with independant management and wasted spark.
send me a pm if you want the number.
Old 16-08-2009, 11:10 PM
RSMK4TURBO
RSMK4TURBO's Avatar
Do they supply all parts needed?
Old 17-08-2009, 07:32 AM
Antti O
Antti O's Avatar
My megasquirt efi conversion cost something like this:
From local scrapper:
Intake manifold, fuel rail, throttle body,brake booster pipe,edis parts (efi flywheel, vr-sensor &bracket,,loom, coilpack+bracket,spark plug wires, edis unit) ~100£
(if you want it look good sandblasting/painting parts costs extra. I sandblasted all parts and get those professional painted.
efi throttle pedal 5£
Another parts:
Megasquirt efi unit v2.2 200£
loom parts 50£
new bigger injectors 200£
efi throttle cable 20£
Fuel lines 40£
Quality cone filter 80£
Custom intake pipe 30£
Innovate wideband lambda 130£ (really important!)
And then the installation costs extra. And i recommend set of NEW injectors, you can newer know what shit those second hand injectors are even if serviced.
Old 17-08-2009, 08:25 AM
liddon21
liddon21's Avatar
Thanks for all your replys guys. I'm really keen to get this done as i want that extra bit of power.
Just been ripped off so many times with mechanics and sprayers so im a bit cautious now.
Old 17-08-2009, 12:57 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
std MFI - STD ford EFI - no gain in power!
Personally if ure MFI is working fine and your not running at 200bhp or whatever then I wouldnt bother converting unless your wanting to tidy up the engine bay, less clutter..
Old 17-08-2009, 01:07 PM
JokerDisco
JokerDisco's Avatar
Somehow disagree. I'm sure everyone who has gone from MFI to EFI has not only experienced better drivability but also some power gains.
Old 17-08-2009, 01:30 PM
orionmojo
orionmojo's Avatar
NMS drive in drive out efi conversion is 2k iirc.
Old 17-08-2009, 04:03 PM
vroooom ptssssh
It Wasnt Me!
What, including me? Hmm..ok.
So how does the power increase from std ford MFI - EFI?
Old 17-08-2009, 05:14 PM
kidsRS
kidsRS's Avatar
Mikeanics supply all parts needed
Old 17-08-2009, 05:18 PM
ricky_2006
ricky_2006's Avatar
efi means easier to gain power and runs better.
not instantly, no way
Old 17-08-2009, 07:26 PM
fonfe123
fonfe123's Avatar
2nd hand injetors are fine providing they have been cleaned and TESTED using a propper injector cleaner and tester.
Old 17-08-2009, 10:04 PM
morph
morph's Avatar
norris uses cossie management which is the same as ODDKIDD CREATIONS so why pay 2k when oddkidd does it cheaper?
Old 17-08-2009, 10:13 PM
morph
morph's Avatar
Another parts:
loom parts 50£
Fuel lines 40£
You have actually paid more than what mine cost to have supplied and fitted!
Old 17-08-2009, 10:31 PM
orionmojo
orionmojo's Avatar
just an option mate.
I use NMS for my turbo, i'd rather pay the extra for karl and ollie to do it cos i've used them before after getting refrences from people on here, my rs hasn't skipped a beat since they touched it over 4 months ago.
If anything happened to it after OKC had converted it and NMS would have to backtrack someone elses work which is both frustrating and again costly for me!.
its swings and roundabouts.
Old 17-08-2009, 10:59 PM
RSMK4TURBO
RSMK4TURBO's Avatar
Cheers mate
Old 18-08-2009, 08:16 AM
liddon21
liddon21's Avatar
at the moment running MFI i should already be hitting about the 200bhp mark.
The last garage that uprated my fuel pump kept saying i would gain so much by going EFI. Better driveability and alot more option to increase the bhp as i cant go much more due to he MFI ????? dunno how accurate this is but can only go from what im being told
To be honest the main reason is i want more power i have enough torque to rip my car in half but want more speed from it. Obviously the better driveibilty will help with the extra power aswell.
Old 18-08-2009, 08:57 AM
morph
morph's Avatar
True! having full efi setup the car is so much better than mfi, igntion is totally mappable, fueling is spot on, and you can have the boost come in in different ways like making it much more proggresive!
Old 18-08-2009, 09:22 AM
matt p
matt p's Avatar
Some people prefer to have work done but people that have a very good reputation.
Personally id rather spend a few extra £'s and have my car worked on by specialists not by someone who runs of his parents front garden.
Matt
Old 18-08-2009, 06:00 PM
Antti O
Antti O's Avatar
Yours included wideband lambda package?
I know my setup is not cheapest you can buy, but i believe it is well worth it.
Old 18-08-2009, 06:31 PM
morph
morph's Avatar
Matt
oddkidd doesn't work from his parents garden? i swear he has his own company and a good reputation at converting to cossie management!
It isn't allways a case of how much something cost that reflects the quality.
2k for something thats nearly 20 years old just seems ridculous!
Old 18-08-2009, 06:32 PM
morph
morph's Avatar
don't know if its wideband its closed loop lambda on mine and all controlled via the ecu o plugins as such if any.
Old 18-08-2009, 08:42 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i'm now running efi, and it's much better than a carb turbo setup or the mfi on my erst powered cab.
ok, ecu £330, wideband £230, inlet/sandwich plate/engine loom £100, injectors £40, miscellaneous parts £50 -pipe etc.
then time an dfuel to map it.
better driveability, better economy than either of the previously mentioned setups, granted mfi isn't too bad on fuel once setup, but lacks the finesse of the efi, on boost and off.
megasquirt isn't for everyone, but decent management can be bought for reasonable money.
just to add i already had bay loom, flywheel and other bits and pieces from a stripped car i had.
Old 22-08-2009, 10:12 AM
liddon21
liddon21's Avatar
well my conversion has come to a sudden halt due to some a** hole driving up my rear and writting off my car
but thanks for the info guys never know might get the engine into another shell.
Old 22-08-2009, 01:45 PM
morph
morph's Avatar
sorry to hear that! reshell it!
Old 26-08-2009, 07:44 AM
O.K.C
Eruption 101.3fm
O.K.C's Avatar
Matt
lol at working out the garden.
Jano did start from his parents garden over 10 years ago working out of a double garage.
We all start somewhere, he worked on his own motors then his pals untill he is where he is today.
Now his reputation is second to none! Even if you prefer others the fact is your tuner is inferior
He has a massive yard with ramps, office, store rooms, diagnostic machines, co machines etc etc.. Charges what the job is worth and will not have you over like many others! Also what i really like is that no-one else works for him. He says that if anyone is going make a mistake on customers cars it will be him only, this way no mistakes will be made.
Also OKC has never advertised anywhere ever. Everything is word of mouth which speaks for itself, if thats not enough then have a good look at the cars he builds.
Mine was in there on this pic,
Old 26-08-2009, 08:33 AM
martinmilne
martinmilne's Avatar
i can never get hold of him want him to look at mine can he set cars up to ?? love his cars and every car he has worked on top bloke
Old 26-08-2009, 08:46 AM
ballin
ballin's Avatar
I would definately consider Jano, nice bloke from my experiences
Old 26-08-2009, 12:10 PM
morph
morph's Avatar
I think its a case of some peeps like to have good excuse as to why they blew 2k for something that can easily be done for 1200-1500! if they think they need to prove to other people that they got a good deal then fair play to them!
Its the same with a 300bhp engine i had a quote for 1 by NMS and then decided to goelse where for a quarter of the price!
Old 26-08-2009, 07:39 PM
martinmilne
[/QUOTE]
i want to work there!
Old 31-08-2009, 06:14 PM
fonfe123
fonfe123's Avatar
everyone has to start somewhere.
MA developments started off from marks driveway.......
Old 02-09-2009, 06:13 PM
Maximum Hustler
Maximum Hustler's Avatar
I will second how good Jano is. My mate bought a cab on L8 management and the from the word go had problems with it. He ended up booking it in at a local tuner who could'nt diagnose a definate fault so he rang Jano. We drove the extra distance (bearing in mind we live in Blackpool) and within an hour Jano had diagnosed and fixed the problem for a very small fee. In this particular case paying more definatley doesnt mean a superior service as Jano is second to none. Would highly recomend.
steve.rst
15-03-2016 08:01 AM
Shaunc
Escort Range
23-09-2015 06:00 AM
RSmark84
13-09-2015 01:29 PM
dms04
11-09-2015 01:57 PM
stevierob
07-09-2015 07:09 PM
Quick Reply: MFI ---> EFI How much £££ and where?
