T3 water cooling pipes
Hi all, am doing a T3 conversion on my fiesta... Just wondering if anyone knows of anywhere that does new metal water feeds pipes from the turbo? cheers Ben
Only come across 2 sets on ebay, one set are new and £120! the other are £50 posted 2nd hand! I had some fancy braided items but they foul on the manifold doh!
..BS Motorsport..
Ive just got some m18 banjo's and bolts from local hose supplier, gonna have to extend my water hose slightly but it should do the job. £20 it cost for the pair. they are ever so slightly larger than the ford ones though, they'll easy fit on the front of the blower but I reckon it could get tight on the rear near manifold, gonna have to suck it and see.
i tried the same approach but found the nut fouled on the manifold side looks like iam just going to have to take the hit on the ford ones as i want it back on the road within the next couple of weeks lol!
http://cgi.ebay.co.uk/SIERRA-RS-COSW...%3D1%26ps%3D33
those are the after market items i have and they are far too bulky, even though the seller said at the time when i bought them off him that they would be fine! radiater side is fine but they foul on the manifold!
them ones foul the manifold, as ive just found out cause i bought em!! try these:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=350227709532
ah not just me then lol!
have you tried these or are you trying to get me to be a gineau pig to see if they fit lol
cheers for the help thus far guys!
rs turbo from Greece...
looks better.May asking something. What modifications need a non water cooled T3 (from S1) to become water cooled as S2 turbo?
ah good man, i just messaged the guy asking for the measurements on the connectors... would you have to get the m18 nuts separately then?
when are you looking to fit them as really i need a solution this week ideally as the car will be back from the paintshop early next week ready to be built up in superfast time (he says lol) hopefully in time for ford fair!
i spoke with the guy who i got the braided items off of ages ago and he reckons he can alter the fixing head to fit, so i will give him a chance to do that first and fingers crossed...
cheers for all the help peeps!
yer i was aware that you can run without water cooling, my dad looks after the car for me and he is keen to keep the water cooling... so its his decison really as he knows a hell of alot more than be about these things than me ha ha! cheers
ok the pipes have arrived! heres some pics:
they look good but look at the size difference between the originals:
and then look what happens when you put the original bolts in:
now if you fit the washers that are normally used youve got no chance of getting that tight properly! it did say on the listing that bolts were supplied so im a little dissapointed they aint in the pack BUT ive not contacted the seller i am going to tho in a minute just thort id show you guys first!!
well the bolts turned up and they are quite big 24/25mm bolt on the end and they do fit kinda, the banjo part itself gets stuck on the bolts that are on the back of the turbo where those metal half moon things are, if that makes sense??
not sure if they leak yet though but they do seem quite tight but will have to see!
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
1800, banjo, conversion, cool, cooled, cooling, kit, kombi, lines, running, t3, turbo, water, watercooled, watercooling
