Fitting Gotech mini X
Power
when you connect up gotech mini x on a s2 rs turbo is it a dash out job or do you just wire in up to the wiring in the engine bay ?
not sure on the min x mate but i have the basic gotech and i got the universil wiaring harnis with it and ran them throught a grommet in the bulkhead its not to hard to wiar up
powered by K26
i cut a 30mm hole next to the battery in the bulk head and feed the wires through, most of the wiring gets used. the ones that dont, just wrap up and hide them behind you dash.
it isnt a dash out job.
Power
interesting, so you do have to wire it up to some wiring under the dash can i just ask to what this is ?
I remember the wiring under the dash is just like some thick loom and i don't know if i want to be cutting into that, if its just simple things like fuel relay then that is not too bad to do myself
track.focus'd
12-08-2015 05:53 PM
