Removing mfi loom for ofab help pls
As above I'm in the garage on the iPhone.have I got to unplug the hole engine loom from behind the dash think this is a job for you lot.cheers
it doesnt unplug on mfi mate.whole loom is one piece.
So I have to remove the hole car loom for a fiesta turbs one.
dont take the whole loom out of your car only part of the wiring in the engine bay,if you look on here i think there is a step by step guide somewere
I have tried to find the step by step guide with no result. Can anybode else help me find it?
Br Butchi |
if it a series 2 fit a full xr3i efi loom so every thing is in the right place ecu fits in the car u will need the stalks and the clocks also the ecu plug will a few pin changes try rsbible .co.uk for this
I've had a nose and found a few good treads
© 2024 MH Sub I, LLC dba Internet Brands
