temperimental starting issues
Old May 28, 2009 | 08:36 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
Default temperimental starting issues
just seeing if anyone knows what my problem is, and anyone that can help!
right i have a 1990 erst s2. on most occasions the car starts fine and runs fine, but on the odd occasion it doesent, it just seems like it floods itself.
it starts but just dies out staright away. it always seems to do it when filled up at petrol station. if i have given it a bit of gas when turning it over, it just seems to make the problem worse, but if i just let it die out and leave it for a minute or so it will start!
any help would be gratefull as its doing my swede in!!!
Old May 28, 2009 | 09:10 PM
Marts's Avatar
Marts
It sounds very similar to mine mate. Does it just continously 'key over' as if it's out of fuel? If so, my issues have Been put down to a dodgy metering unit. Try taking off the lower boost pipe and see if anything pours out!
Old May 28, 2009 | 09:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Idle mixture is too rich or too lean.
Old May 28, 2009 | 09:26 PM
Marts's Avatar
Marts
Set up is the only answer then Karlos?
Old May 28, 2009 | 09:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No mate, you can quite happily adjust the idle mixture yourself! Try 1/4 of a turn at a time anti-clockwise until it idles lumpy then clockwise 1/4 and you should be about right. Set your idle speed after this, but also in your case Marts you MUST bung the idle mixture screw hole!
Old May 28, 2009 | 09:44 PM
Marts's Avatar
Marts
My hole is now bunged! Thanks
Old May 28, 2009 | 09:46 PM
Karlos G's Avatar
Karlos G
Balls Deep!
LOL
Old May 28, 2009 | 10:21 PM
dan-dan's Avatar
dan-dan
sean is your cold start valve still pluged in? could be faulty?
Old May 29, 2009 | 09:29 AM
Marts's Avatar
Marts
If the cold start is faulty, surely it would have the same affect as it being unplugged? Most run/start better with it unplugged anyway
Old May 29, 2009 | 09:38 AM
dan-dan's Avatar
dan-dan
Most MFI's start better without but it could be suppling to much fuel also
Old May 29, 2009 | 06:18 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
i have dissconnected the cold start valve, and yeah it does just key over continuously like its out of fuel! i will have to try taking off lower boost pipe! am sure my car is set up right fueling wise
Old May 29, 2009 | 06:38 PM
Marts's Avatar
Marts
It's not that mate, the fueling can be set up correctly, but the metering unit can break at anytime!
I'll keep an eye out on this thread to see if and how you get this sorted. If my issue gets sorted beforehand, I'll let you know what I did
Bailes1992
Sep 3, 2015 02:17 PM
Bailes1992
Aug 16, 2015 07:14 PM
Red_bull
Aug 9, 2015 08:34 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
