Is this wiring dodgy
Just wiring in some gauges and have decided that rather than having 6 seperate wires for earth and illumination coming from the gauges I have put all 3 earths into one block and all 3 illumination wires into one block (see bottom left) - one wire from each will then go to the back of my clocks for illumination and one will go to earth (now all 6 wires go into only two wires- fused of course.
Is this dodgy??
Minter - thought as much!!! Only thing is I've run out of that small cable and only have 1.5 cable left will this make a difference if i use this size cable on the other side of the block connector?
Also I will be doing the same with the ign live, switch and ground from the gauges for the sender units and sensors
ran out of solder and chocolate blocks come free of charge with the clocks.
TPM961
15-01-2018 10:50 AM
Mark RS
12-10-2015 06:01 AM
