ester oil any good?
ester oil any good?
Hi guys i can get castrol 10-40 synthetic ester oil for my series 2 i was just trying to gauge what you think i know oil topics have been done to death but i dont want to blow my new engine up and have done a search and cant find the oil i can get, so dont know if its any good. hope it is as i can change my oil every month then
Also its magnatec oil (what they use in type r's)
thanks
Tel
thanks
Tel
dont worry guys i found what i was looking for.
Oil Advice and Recommendation
Views: 2,534 Posted By oilman
5w-40 or 0w-40, we found best results with an...
5w-40 or 0w-40, we found best results with an ester based synthetic such as the Silkolene Pro S 5w-40.
competant bodger
dont use magnatec unless you want a noisy engine!!! i personally use 10/40 millers xss in mine its a high ester semi synthetic and is perfect for rsts, fully synthetic can cause noisy tappets in anything other than a freshly rebuilt engine, as a rule you should never use fully synthetic in an engine used with semi as the wear already produced can cause trouble with the thiness of a synthetic especially with anything with a 5 rating!!! i say the thicker the better with an rst, i also put 4 litres in mine instead of 3.5 as this allows for oil surge on a wll handling car without causing issues with the rods dipping in the oil
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
