bailey header tanks
bailey header tanks
to those of yous with stainless baileys header tanks....did you fit it in the same place as the standard or did u have to move it down a bit? put mine on today in the original place but the bonnet wont shut and moving it down kinks the bottom hose...i know i could just cut the hose etc but wanted other peeps thoughts..cheers...(its a s1 btw)
you need to bend the brackets slightly mate, use the top mounting holes and then just drill some new lower ones- had already been done to mine as i bought a used header tank
