escort rs turbo tempiture sender
Old 09-02-2008, 10:52 PM
turbocat
turbocat's Avatar
Default escort rs turbo tempiture sender
escort rs turbo tempiture sender Why is there so meny colours what are you guys running mine is purple It says its hot very fast and the engine is still just warm my mate has a blue one on his and seems to run right on the dial
Old 10-02-2008, 09:17 AM
©hatter Box
©hatter Box's Avatar
if it any thing but pink you got the wrong one
Old 10-02-2008, 10:47 AM
Barry R
Barry R's Avatar
thats why mine never reached the half way mark then
Old 10-02-2008, 07:05 PM
turbocat
turbocat's Avatar
What was yours
Old 11-02-2008, 05:36 AM
Butchi
Butchi's Avatar
Where is the sender located?
Should it be purple to the rst?
My gauge almost never moves more than a few millimeters. Maybe I got the wrong sender?
Mvh Butchi
Old 11-02-2008, 04:34 PM
Moonie
Moonie's Avatar
The temp gauge sender is located in the front of the head (exhaust side) next to the thermostat housing and has a single wire going to it.
The ECU temp senders are located at the back of the engine under the inlet manifold.
The radiator fan switch is located in the thermostat housing
Old 11-02-2008, 05:22 PM
Butchi
Butchi's Avatar
Thanks for the answer.
Is the hole sender purple?
Is the fan only connected to the thermostat housing and get the signal to run from here? No impulse from the ECU?
BR Butchi
Old 11-02-2008, 05:44 PM
Moonie
Moonie's Avatar
The sender for the gauge should look like this.....
The fan switch in the thermostat housing is just a "switch" which turns the fan on and off. The ECUs have nothing to do with coolant fan operation.
Old 11-02-2008, 05:46 PM
Moonie
Moonie's Avatar
The temp senders on the back of the engine can be seen here...
Old 11-02-2008, 06:17 PM
turbocat
turbocat's Avatar
So should it be a pink one my ford dealer said They did one for all and its purple has anyone no where I can get the one I need
Old 11-02-2008, 08:17 PM
Moonie
Moonie's Avatar
Which one do you need, the one for the gauge? Where is it located on your engine?
Old 11-02-2008, 08:46 PM
turbocat
turbocat's Avatar
The one on the front of the engine that you put a pic of
Old 12-02-2008, 12:22 AM
Butchi
Butchi's Avatar
Now I know where the sender is located and the picture you showed us over a brand new sensor looks like its white in the top end.
I think there are only one sender thats fits here. How said anything about purple?
Mvh Butchi
Old 12-02-2008, 10:34 AM
srlew
PRO BISCUIT DUNKER
srlew's Avatar
no mean to hijack, but iv just been connecting plugs etc to my engine and i needed that info in the pic, but just noticed that the grey plug temp one, i havent got one lol, also would that mean that the plug on the loom that connects to it is grey?
Old 12-02-2008, 04:10 PM
Moonie
Moonie's Avatar
Yes, its a different connector/shape to the others on the back of the engine so you cant get that one mixed up.
Turbocat - according to the information on here...
https://www.burtonpower.com/product_...=temp%20sensor
Part No: XTT8 - Replaces Mauve sensor on the CVH.
I got a new temp gauge sensor for my Escort from my local motor store.
Old 12-02-2008, 04:52 PM
homer j
homer j's Avatar
the temp gauge sender for the erst has a red band on it.
Old 18-01-2009, 04:55 PM
MattRS171
CAR FOR SALE!!!
MattRS171's Avatar
Everyones saying all these different colours n the one from burton is yellow. this sensors causing havoc on my RST, start problems the lot need one quicktime.
Old 18-01-2009, 10:47 PM
Micky
Micky's Avatar
Thats got nothing to do wit hthe temp sensor for the dash guage!Regards,mIcky
Old 19-01-2009, 02:24 PM
MattRS171
CAR FOR SALE!!!
MattRS171's Avatar
Right so which one is for the gauge the one on the back of the engine with the cold start or the one on the front. coz the lad that had car before me has just got a single wire going to the one at the front of the engine and it is just reading max heat all the time. any help??
Old 19-01-2009, 08:25 PM
Micky
Micky's Avatar
The sender for the temp guage is on the front of the engine.It has a single wire,with a push on connection.Regards,Micky
Old 19-01-2009, 08:59 PM
Rick
Rick's Avatar
it was always pink, they may have changed it. It really doesn't matter as the gauge isn't calibrated. If it runs 1/4 way normally, and it shoots up to 3/4 - you know u have an issue.
Old 20-01-2009, 10:40 PM
MattRS171
CAR FOR SALE!!!
MattRS171's Avatar
Cheers lads. Went up local egine rebuild place today not even a ford breaker or owt n hes got loads cost me 6 quid n its solved everything.
Old 20-01-2009, 10:47 PM
dangerousbrian
dangerousbrian's Avatar
what colour did you get then?..i have a red 1 as thats the only 1 i could get..have been told it should be pink aswell
Old 20-01-2009, 11:00 PM
MattRS171
CAR FOR SALE!!!
MattRS171's Avatar
mines got a clear cap on it, not an original ford part, but the bloke i was talkin says it doesnt matter shit what colour they are as long as its the same sensor!! and hey its worked for me ide rather pay £6 n it works than huntin round payin£10-£30 per sensor till i get the right one, ill update if it goes tits up lol but its bin on all day today drove car about n give it some beans n car was fine n gauge was faultless
Old 01-06-2018, 07:43 PM
kev872003
kev872003's Avatar
what colour is the wire to the temp gauge sender
Old 02-06-2018, 04:21 PM
Rusty85
Rusty85's Avatar
Default Correct sender.
The temperature gauge sender on mine is original. It has a spade terminal, although some cars may have the round pin. The 'blade' sender should have a mauve insulator. Half way between pink and pale blue. Mine runs about 40% range normally, with the fan coming on at about 75% range. It was nearer the top but I put a lower temperature fan switch in to deal with more queues nowadays.
Old 02-06-2018, 04:36 PM
Rusty85
Rusty85's Avatar
but it may have a flat 'spade' terminal......
Old 02-06-2018, 04:39 PM
Rusty85
Rusty85's Avatar
Red and white. To be more exact, on mine the original has 4 equal width bands around the circumference, alternate red and white.
Old 28-11-2023, 12:14 PM
rsturbolee
rsturbolee's Avatar
So to conclude
it should be white red blue pink and possibly yellow 😂😂
what one do we need? My s2 guage reads too high
Old 30-11-2023, 07:46 PM
boost monster
boost monster's Avatar
Mine is Black!
The first one I bought as a replacement last year had the gauge reading high and swapped it out for the current one which is black.
I think the colours are irrelevant unless they are all from the same manufacturer.
I matched the cold resistance of the current one with the original but can’t remember what I was. I will measure it tomorrow and reply.
Old 01-12-2023, 09:57 AM
boost monster
Done some testing this morning.
you need this resistance at ambient (currently around 8c in my garage.
This will make the gauge read normal. Unfortunately I can’t remember where I got it from but they stated the resistance in the specification so I knew it was correct compared to my original.
My previous sensor.
This will make the gauge read hot.
3i Jim
20-11-2015 05:12 AM
Matt Baxter
16-09-2015 08:30 PM
FlashRS
14-09-2015 12:36 PM
muz
16-08-2015 12:57 PM
adriansaleem
01-08-2015 09:28 PM
Quick Reply: escort rs turbo tempiture sender
