2wd.or.4x4.turbo.on.ZVH?
What's.best.for.my.2.0.zvh.in.my.rst?
Which.one.spools.up.better.and.wich.can.handle.moo re.boost??
Lookking.for.1.3-1.5.bar.
Thanx
Thanx
Originally Posted by T28 RST
I.think.you.should.buy.a.new.keyboard.first
My laptop keyboard is broken :P
Wil send it off monday because i've stil got warrenty on it.
But on topic..... wich one should be better for me?
The 2wd will be slightly better on spool up, but i doubt your notice it.
The only difference between a 2wd and a 4wd cossie t3 is
2wd has a 55trim comp wheel, and the 4wd has a 60 trim comp wheel.
Go for 4wd...
Go for 4wd...
Originally Posted by Berry RST
I've heard that there isn't much difference between them..
I think the 4X4 is a bit laggy....
I've got a 2WD, but.......you allready knew that
Don't.want.lag.as.my.engine.won't.rev.beyond.6000r pm
hope.it.will.be.better.on.EFI
Originally Posted by crazycage
what power do you want
should.be.something.like.270-280.bhp.i.think..
should.be.something.like.270-280.bhp.i.think..[/quote]its all down to the head mate im getting that @1bar on a cvh with a stg3 4x4 t3
Got.a.standard.head.at.the.moment.but.will.swop.it .for.a.EFI.head.wich.i'llbe.working.on.myself...
But.then.again...what.wil.be.better.for.my.ZVH.eng ine?
don't.want.to.much.lag.but.do.want.to.run.1.3-1.5.bar
thanx
thanx
thanx
thanx
If.you.know.how.to.....why.can't.you.do.it.yoursel f...
ok,maybe.i.won't.get.every.last.horsepower....But. i.haven't.got.a.moneytree..
8:1
ok...thanks.for.the.advice...i'll.rethink.my.porti ng..:P
But.wich.turbo.would.be.better.as.i.can.by.one.for .a.good.price.now.
ok.thnx....
can.get.a.2wd....little.les.lag.but.also.les.toppo wer.....
Got.a.really.smokey.standard.t3.now.so.need.someth ing.else..
wil.think.about.it
wil.think.about.it
Originally Posted by JesseT
Just changed my failing 4x4 turbo to a 2wd turbo and I didn't feel a thing change.
i've brought 2 std 2wd turbo's, and both had 60 trim 4wd comp wheels fitted.
