Compression ratio Help
Old Sep 22, 2004 | 08:55 PM
Drjones's Avatar
Drjones
Default Compression ratio Help
Alrite ppl
Went to order me pistons etc today and i need to no what compression ratio i want and i dont no how to work this out.
my engine spec is
Big Valve head with matched manifolds
CVH35 Cam + adj pulley
felpro gasket
cosworth pistons
H section rods
stage 2 T3
pro ally intercooler
ERL water inj
It will be getting live mapped
Any one any ideas what i should go for and do you thing that this should be a decent engine????
Old Sep 24, 2004 | 09:35 PM
gavintwopies's Avatar
gavintwopies
does a bear shit in the woods ???
of corse that engine spec will be good..................... what various compression ratios are available from your supplier and what boost levels are you going to run???
Old Sep 25, 2004 | 08:02 PM
Drjones's Avatar
Drjones
it will be boosting at around 15/16psi i can have what eva compression ratio i want
Old Sep 29, 2004 | 11:21 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
depends what power you want how you want it to drive ect ect
Old Sep 29, 2004 | 10:50 PM
DazC's Avatar
DazC
Default Re: Compression ratio Help
Originally Posted by Drjones
felpro gasket
Oh dear!
And on the compression ratio, it depends on what you want from the engine. Plus you need to know the combustion chamber capacity to work out how much to machine the pistons by....
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
