non starter erst s2 ... again
#41
Thanks ivorbiggun I will try this
Today I have checked some things:
1) I removed the injectors, bridged the fuel pump relay and push the flap of metering head, the 4 injectors sprayed the same quantity of fuel
2) I double checked for an air leak, there is not...
3) the fuel pump pink relay has the plastic burned at the base, but it works, I dismounted (sorry I don't know the right verb), it closes...
4) I Test the compressions of the engine (cold ), I have:
Cylinder 1 10.5 bar
Cylinder 2 10.5 bar
Cylinder 3 10.5 bar
Cylinder 4 10.5 bar
So ... there is fuel at the exit of metering unit ...
Cylinder 1 10.5 bar
Cylinder 2 10.5 bar
Cylinder 3 10.5 bar
Cylinder 4 10.5 bar
#42
I had a similar problem last year which (after I changed literally everything/pump,relay,accumulato,regulator,metering head ,injectors+seals,
manifold gaskets, distributor, leads and..... well you get the picture) finally
turned out to be the cold start injector which was leaking ALL the time.
If the Easystart works and subsequently the engine starts fine whilst hot
but is difficult to start after it's sat ifor an hour or so then I'd say thats
your problem.
your problem.
#43
I checked the spark on cylinder 1
there is a spark 5seconds, then increasingly small and after nothing ... just a ticking noise in the spark plug ...
#44
First thing I'd try would be the Coil, then (another favourite in my experience) check the connection of the large block on the rear of the ignition ecu/the pins sometimes corrode, then maybe think about that distributor of yours just because something is new (or nearly new) doesn't guarantee it's
integrity.
integrity.
#48
ivorbiggun
plugs are black and smell fuel
When hot (It's happen one time, when the "breakdown" appeared) there is explosions you can idling the engine at 300rpm if you stay on starter ... and there is a lot of backfiring in the inlet
#49
Take ALL plugs out and put the in the Oven for 20 mins on a high heat this will purge them of all unburnt fuel. Whilst they are warming up, turn the engine over a few times to purge cylinders and inlet of the same.
When plug are VERY hot remove from oven and carefully replace into
cylinder head and START.
#50
Jack-of-all-Trades surprised to see ivorbiggun is actually posting something constructive for once, dont think easy start is your solution though.
Your compressions are good, and you have fuel spraying.
Now, your burn marks on the fuel pump relay, your pump is on its last legs i can tell you that much.
If you are getting back fires in the inlet it sounds like something is majorly out of time, can you DOUBLE CHECK the HT leads are on in the correct order for me.
#51
With dizzy in front of you (top to bottom, left to right):
3 1
Coil
4 2
I take some pictures of dizzy, and fuel pump relay, I will upload them
On the dizzy cap, in side on the connectors of ht leads there are blues deposits, there are "striped"
#52
Some pictures:
fuel pump relay
http://www.kirikoo.net/images/2Jack-...327-164545.jpg
dizzy cap
http://www.kirikoo.net/images/2Jack-...327-164546.jpg
http://www.kirikoo.net/images/2Jack-...327-164712.jpg
rotor arm
fuel pump relay
dizzy cap
rotor arm
#53
You need to time the engine up so number 1 is ATDC, then remove the dizzy cap and work out where number 1 should go, then fit the rest in the firing order!
Theres a lot of technical data things going around with incorrect diagrams on them!
#54
#56
1342 correct
Check you have number 1 in the right place by looking at the rotor arm and then work around the dizzy anti clockwise
#58
Ichecked if there is a good spark ... and there is not a good spark !
When you're cranking during 5s there is a spark, then more and more smaller, then no spark just a ticking noise in the spark plug ...
I'm not sure about my dizzy, can you take a look of my pictures ? Is it good ?
#59
Is your battery ok........?
Its hard to see in the pictures, ive seen worse dizzy caps couldnt really say if yours is ok or not tho. That fuel pump relay looks a lot like mine i took out of the cabriolet, you WILL need a new fuel pump soon.
#60
Battery is ok, it has two months
#62
Might be worth trying another ECU if you can borrow one.........being as the dizzy is new.
I "refill/recharge" the battery, it's better, the car wants to start, some explosions during the first second when I'm cranking, after nothing more...
#66
it wont be the pump, leave that until when you've fixed it.
I would continuity test your loom
thanks for your help
#67
I am a ... I can't find the right word for this ...
There is a small black hose at the side of metering unit ... it was unplugged ... I repace them and It starts ...
But there is backfire in the exhaust when idling ...
Perhaps It's the fuel pump ?
#69
Picture of the hose please
Sounds like either the breather hose or the amal valve waste pipe.
But my idle is oscillating between 800 and 2000rpm and it's backfiring a lot in the exhaust ... :/
#71
Put something in the pipe on the metering unit to block it off, you are elimating the whole engine from being a potential air leak then
(mine currently has a 3/8 - 1/4 socket adapter in there )
#72
SafeChav
I think I don't understand what you mean. Did you mean I have to "close" the durite or I need something to "secure" it (a "collar" for example)
Now I need a Good setup, on rollers !
But in north of France I don't know who can do that
#73
Originally Posted by Jack-of-all-Trades
SafeChav
On the metering head, theres a short rubber pipe that connects to the long hard plastic breather pipe, block the rubber pipe on the metering head off for now, it will stop the whole engine from interfering with the cars running, if you get an air leak anywhere on the engine it causes problems on MFI.
#74
if the cars idleing a little rough at first, just keep the revs to around 1000rpm as best u can for a couple of mins, dont forget with air leaks and being flooded with petrol its going to be a bit rough to start with
#75
and again !
The car was running fine and today it won't start
I have no airleaks,
There is fuel, there is spark (not really good but there is a spark), ht leads are ok, I got spark at exit of coil ...
I'm really borred....
If anyone have an idea ...
I have no airleaks,
Mc5506
05-10-2015 09:57 PM
