Series 1 Fuel pump relay help
It Wasnt Me!
Got this fuel pump relay in a swap, but noticed the pin far right on its own wiggles from left-right..butim assured it does work.
Does anyone know what this pin is for, is it an earth or soemthing?
Also, My car is a series 1, but has a series 2 fuel pump relay holder, I got the car with a wire bridging the fuel pump to run constantly, as no relay was present...
Im not sure if its only the holder that has been changed, im assuming it was changed to accomodate a serie 2 fuel pump relay as they are easier to get a hold of....however ive got the series 1 relay as its more reliable than a series 2 effort and im told the wiring positions (if previously changed for an S2 relay) can be swapped back round in the S2 holder to refit the s1 relay....does anyone know which wire goes to which pin on the S1 relay? and what about this extra pin?
beside the pins on the relay I have the numbers:
30
31
87
15
And the one on the other side on its own is:
50
any help would be appreciated, would like to get it running on the S1 relay for friday when im insured to drive the car legally for the first timeever in 3yrs
It Wasnt Me!
Terminal Number Connection
30 Permanent battery live
31 Earth
1 or 31b Coil negative
15 Switched 'Ignition on ' voltage
87 Output to fuel pump
Would these be correct for a series 1 relay?
31 Earth
I think your right dave ( 1.45 am and raiding my haynes manual for you by the way )
30 PBL
31 earth
1 coil
87 fuel pump
15's a brown wire which im sure is the ingnition on as said but cant guarentee it, so long as your wiring is still in the original nic ill get a photo of mines tomorrow after work and post it up for you
do any of the other spades wiggle at all? if so crack it open and give it a clean up and a solder and itll be righ as rain.
30 PBL
31 earth
1 coil
87 fuel pump
It Wasnt Me!
Ive had my head stuck in the haynes too, and for the life of me I cant work out the wiring diagram on WD.11
I meant to type pin 50 not 15
thanks for your help Pete, appreciated at this rate i'll be takin it to my auto spark with S1 AND S2 fuel pump relays and left in a locked room until it comes out running
fuck i thought i was up late
the haynes diagrams are bit on the cryptic side though mate, thing i was mesing about with my regulator and wiring not that long ago, ive not driven my car since october and its pissing me off
It Wasnt Me!
I'd jus woke up...fell asleep on the couch lol
I dunno what to do, ive got 2 series 2 relays I could try (but they need repaired) dont want to plug in either relay incase its wired for the opposite one and I blow sumthing
It Wasnt Me!
Thanks allot Pete, could you see if you can see where pin 50 goes? cheers bud. I think i'll take it to my sparky as dont wanna mess it up an wanna know its alright, he'll prob do it for a fiver, will get him to check wiring is sound and pump isnt drawing too much current etc
Dave, Relay deffo works. Hadn't noticed the single pin being a bit shoogly but the other one had a bit of a rattle from inside and although worked I wasn't wanting to give you that one.
I've had a look at my wiring tonight for you. tried to take a pic but not easily accessible. so here goes
Pin 30 :- Thick red wire (Live Feed)
Pin 1 :- Thin green wire with either a red or orange (couldn't make out clearly)stripe running down it
Pin 87 :- 2 thin black wires with red stripe
Pin 15 :- 1 thin solid black wire and also 1 thin black with green stripe
Pin 31 :- Brown (Earth)
Pin 50 :- has a small single black plug with a thin black wire with yellow stripe
Hope this helps mate
SMG
SMG
It Wasnt Me!
Smiggy, no problem at all man, I trust it works
Thats a huuge help, and hopefully when I go and have a look tommorow i'll be able to find all these wires and get it wired up! great help mate cheers!
Im just wondering about pin 50 tho, what it actually does, I think its some sort of switched earth? but will I be able to use the relay without tht wire if I cant find it...I know the S2 relay doesnt use it so it must still be their hanging about or wired to something else?
cheers again mate
Right, I know 30 & 87 are what I bridge just now, this looks to be the same for the S1 and S2 relays for main power feed to pump, so jus need to figure out which other wires I swap round if any?
cheers again mate
No worries, looks like all the wires come off main loom coming down from fuse box area. Don't know about it working without the single connection on. I can try that for you tomorrow night. If my car was taxed and that I would bring it round yours and we could have a go at it then with something to compare with but will be mid april before I get mine on road.
It Wasnt Me!
Good man that would be a help if you could try it! cheers
I'll get their, if I cant i'll just take it to my sparky as mentioned, im ared now with what wire is what its just a case of changing them now I think (apart from that damn pin 50...altho im sure its jus swinging about under my dash!! will let you know tommo)
Thanks smiggy, hopefully mine, yours and petes will be working and we'll get them parked up beside each other next PF meet!! dont wash your cars tho so mine looks a bit better
vroooom ptssssh im really sorry mate havent had a chance to get into the manuals!
Not ignoring ya or anything like that! I get so many PM's these days asking everything under the sun, its hard to keep up
It Wasnt Me!
SafeChav, No worries mate, I can immagine how busy you'll be these days bein prob the only PF ERST spark lol!
I think ive kinda cracked it, jus that pin on its own im confused about, hopefully when I go to check the wires tommo they'll all be the right colours and present so it'll be jus a case of configuring them in the right order.
proper ball ache when you know absoloutly jack all about it/wiring tho
If you get a chance let me know what you come up with cheers.
Nah i just feel like a cunt when i know i can answer the questions but havent actually answered them!
I had to convert that S1 i worked on to accept a S2 relay, and it worked first time
It Wasnt Me!
Ach dont be daft man, as long as I can get it changed by saturday to run A relay prefferably S1 i'll be happy as thats when my insurance starts, givin the car a good seein to tommorow so while im at it could check the wiring then to see whats what.
im assuming its been changed to an S2 relay, why else change the holder (altho why change it in the first place, instead of jus swappin wires? )
Right.......there will be a couple of things to do though.
You may find the green/red in your car has been cut and joined, being as the S1 relay needs a 5v Square Wave input from the dizzy, and a purple relay needs a switched earth to operate.
And 50, is Black/Yellow as i said, its an ignition feed from the switch! Should be a surplus black yellow in amongst your wiring.
It'll be joined up to the rev counter wire i expect, green!
It might not be though, did yours have a S2 relay in it? Or just the bridge wire?
Originally Posted by Moonie
50 is a cranking feed (only live with the key in position 3)
I fucked up there! Thought it was wierd when i posted it
It Wasnt Me!
Right, it appears all wires are present, even the black/yellow
Jus gotta swap them about now, I reckon i'll take it to monj auto spark on saturday, he'll prob do it in 2 mins an charge a fiver, an if it breaks...its his fault
Cheers for the help, mucho appreciated!
Now on to my next problem.....le overboosting
Mate you can't be serious after that!
Just use a very small precision screwdriver to unhook the terminals and re-insert them back in their corrects places.
Its SO easy you are throwing money away if you pay someone else to do it!
It Wasnt Me!
He'll only take a fiver, its my pals pal...I jus dont wanna fook it up
See the wire you said 'might' be connected to the rev counter, would the end of it be connected to the relay holder but maybe half way up the wire, connected to the rev counter one? or is it if its jus connected to the relay holder, its not near the rev counter?
A fiver is a fiver mate, and even more so to both yourself and me, we are both in the same boat!
The Green/Red may be connected elsewhere........if its had a bridge wire in it since u bought it, my guess is it wont be cut though, the probably plugged the purple relay in and when it didnt work gave up and used a shitty wire!
Nothing ventured nothing gained mate..........as long as u keep that red well away from shorting out on anything you'll be fine (as the red is unfused)
It Wasnt Me!
Yea, well this is true! spent some cash on it today, jus small things, got new braided fuel hose as other was rotten
Cool, i'll trace the wire back then and double check it! your convincing me to try this myself I suppose I cant go wrong, ive got all the info I need...it's jus the fatefull "click" as you turn the ignition on that im worried about
Above all.........you dont just swap wires round and plug it in and hope for the best, test what youve got before plugging the relay in!
Check, check, and double check! Ive not had any problems
So you dont know how to set a dial to 20V DC range, and test for 12v
And you cant set it to continuity test and look for a reading as close to 0 ohms as possible to continuity test wires
JK12
33
26-04-2021 12:09 PM
