lowering my series 1 need ur opinion everyone
Old 28-01-2007, 09:57 PM
timturbo
timturbo's Avatar
Default lowering my series 1 need ur opinion everyone
my series 1 on koni adjustables i was thinkin going coilovers but konis are so gd changed my mine i want to lower them though do i just get shorter springs. 60mm drop on standard 15's. would i have get uprated springs too ur help please everyone
Old 29-01-2007, 03:48 PM
gaz s1
gaz s1's Avatar
60mm is too much will kill ure handling and probably ure konis as well 35mm on konis max
Old 29-01-2007, 04:00 PM
Bakster
Bakster's Avatar
Here you are my S2 on koni adjustable shocks and -80 front -60rear springs
Old 29-01-2007, 04:09 PM
Mixja
420
Mixja's Avatar
love them wheels...!!! lol
Old 29-01-2007, 04:14 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Koni's aren't made to take that amount of lowering. Escort's don't benefit from it either.
30mm!!
Old 29-01-2007, 04:45 PM
SafeChav
SafeChav's Avatar
30mm!!
Your just gettin old and can't take the stiff ride
Old 29-01-2007, 04:48 PM
Christian and Beccy
#1 in Spelling Club
30mm!!
LOL. That's the one!!
Thanks!
I have these visions of taking my RST to the Post Office to draw my pension!!
Old 29-01-2007, 05:00 PM
SafeChav
SafeChav's Avatar
30mm!!
Thanks!
You know that would be
I have visions of that too.......but whats the chances of our Ford's being not rotten when were that age
Got a question i wana ask you aswell, ill send a PM now
Old 29-01-2007, 05:23 PM
rs shawn
S1 Database Editor
rs shawn's Avatar
I agree that 60mm is too much. Especially for a lot of town driving..poor surfaced roads and pot-holes all over the place. Bumpy roads..etc.
You'll need uprated springs to get the best out of them if you wanted ot lower it. Standard springs will make it sit too high and would undo the work the Konis did.
Old 29-01-2007, 06:45 PM
Christian and Beccy
#1 in Spelling Club
30mm!!
Thanks!
I'll be lucky if my RST isn't a pile of cornflakes on the ground by the time I'm 35.
Old 29-01-2007, 09:21 PM
SafeChav
SafeChav's Avatar
I'll be lucky if you read your bloody PM's once in a while
Old 29-01-2007, 10:27 PM
timturbo
timturbo's Avatar
Christian and Beccy
what do you mean konis cant take them? i want to lower her gettin her sittin on wheels do i have go coilovers then?
Series 1 not on road blown inlet valve only had it 5 days
Old 29-01-2007, 11:25 PM
NUTS RuS
NUTS RuS's Avatar
By lowering it that much your putting the damper under permanent compression, which its not designed to do.
After a while during use the oil heats up the gas making it either lose its compression, so the damper no longer works effectively, and off you go bouncing down the road looking like a twat, or in some cases it expands the oil and breaks the seal and leaks everywhere.
HTH
Old 30-01-2007, 12:56 AM
Ade
Fast Ford snapper
Ade's Avatar
Steels can look seriously tough, the Vee Dub boys know what I mean
I've had experience of an RST sitting -60mm and then -30mm...... drove terrible at -60 but you could say it was almost worth it for the looks
Old 30-01-2007, 08:54 AM
rs shawn
S1 Database Editor
rs shawn's Avatar
Never sacrifice how it drives purely for the looks if the handling is that bad. What good is a top motor parked up gonna be if it's in a hedge the first time you get on a B road? Compromise is where it's at. You want it slammed at a show or as you cruise past? Get airbag suspension or hydraulics. You want it to be able to safely drive along a road..compromise.
The steelies *could* look good partly polished. Or if the centres were cut out & turned round so they became deep dished. Seen it before on a Mk1 or 2 Escort I think it was. They were different style tho. Only had 4 spot welds holding the centre in place originally. Cut them off, turned them around and welded the whole centre. Totally transformed the look of the wheel.
Old 30-01-2007, 12:05 PM
chelseabully1
chelseabully1's Avatar
you have a pm
Old 30-01-2007, 12:13 PM
rs shawn
S1 Database Editor
rs shawn's Avatar
Who...
If it's me..I ain't.
Old 30-01-2007, 07:11 PM
timturbo
timturbo's Avatar
thanks alot everyone nice one
Old 30-01-2007, 07:16 PM
Mr S1
Don't ask - I don't know
Mr S1's Avatar
25mm drop. Plenty enough.
AJC
08-10-2015 11:09 AM
Kiran1600E
11
02-10-2015 11:35 AM
M7 COS
Wheels and Tyres
01-10-2015 04:46 PM
Fudgey
21
30-09-2015 06:19 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: lowering my series 1 need ur opinion everyone
