how hard would it be to...
...put a digital dash out of an astra gte in to my s1 as im sure ive seen that in a escort cabrio before & i reckon it'd look well smart
Wouldn't be that hard to get the basic functions working, but things like the oil pressure gauge and oil level could be hard to get working.
And personally, if it wasn't all working, i myself would never be happy with it
Theres a guy on retrorides who has done this to his mk3 escort, his username is Street (used to be on here often in the past)
THe only problem was he didnt have space to use the warning lights and had a seperate pod for them, but then he wanted to keep part of the original dash facia
Link to the thread on RR
http://retrorides.proboards86.com/in...4883063&page=4
this mite be of some use....
ASTRA GTE DIGITAL DASH INTO A MK4 ESCORT
BIG PLUG
ASTRA DIGITAL DASH FORD DASH
PIN NO COLOUR FUNCTION PIN NO
1 BLACK/GREEN INDICATOR RIGHT 1 ON BLUE PLUG
3 BROWN/WHITE HANDBRAKE 6 ON BLUE PLUG
9 BLACK IGN + YELLOW WIRE ON BACK OF IGN SWITCH *
13 WHITE/YELLOW HEAD LIGHT WARNING 6 ON WHITE PLUG
14 WHITE MAIN BEAM 9 ON WHITE PLUG
15 BROWN GND - MOUNT ON GOOD EARTH POINT **
16 BLACK/WHITE INDICATOR LEFT 2 ON BLUE PLUG
LITTLE PLUG
1 BLUE/WHITE ALTERNATOR LIGHT 4 ON BLUE PLUG
4 BLUE/BLACK FUEL GAUGE 2 ON WHITE PLUG
5 BLACK IGN + YELLOW WIRE ON BACK OF IGN SWITCH *
7 GREEN REV COUNTER 7 ON BLUE PLUG
9 BROWN GND - MOUNT ON GOOD EARTH POINT **
10 BROWN GND - MOUNT ON GOOD EARTH POINT **
11 BROWN GND - MOUNT ON GOOD EARTH POINT **
12 BLUE/YELLOW OIL PRESSURE GAUGE IF YOU DONT HAVE A OIL PRESSURE GAUGE THEN NOT CONNECTED
15 BLACK IGN + YELLOW WIRE ON BACK OF IGN SWITCH *
17 BLUE ENGINE WATER TEMP 10 ON WHITE PLUG
21 BLUE/RED SPEEDO CONNECT TO BLUE RED ON SPEED SENSOR
22 BLUE/GREEN OIL LIGHT 8 ON WHITE PLUG
EXTRA NOTES
* THESE NEED TO BE CONNECTED TO A SWITCHED LIVE SO I USED THE YELLOW WIRE ON THE BACK OF THE IGNITION SWITCH
** THESE NEED TO MOUNTED TO A GOOD EARTH POINT
GEARBOX SPEED SENSOR
THERE ARE 3 WIRES ON THIS SENSOR
BLUE/RED CONNECT TO BLUE/RED WIRE ON THE LITTLE PLUG ON DIGITAL DASH PIN NO 21
BLACK I RAN THIS STRAIGHT TO THE POSITIVE SIDE OF THE BATTERY
BROWN I RAN THIS STRAIGHT TO THE NEGITIVE SIDE OF THE BATTERY
the plugs on the ford dash i have gone left to right when looking at the back of the clocks i did not go by the numbers on the clocks
the pin out on the ford side will be different on the different models these are for the clocks out of a h reg xr3i efi but you can easy find out what ones you need by folling the tracks from the plugs to the gauges or light you need
BIG PLUG
LITTLE PLUG
EXTRA NOTES
The Youth.
30-09-2015 09:59 PM
SMILER258
28-09-2015 09:04 AM
