Help Tubular manifolds
#45
Gotta take my hat off to u mate that some good work.
What one do u mean by: -
use a 3 bolt cossie one then,that would b better
Cheers,
Jim
Cheers,
Jim
#48
So, if you have a cossie 3 bolt housing, is this a straight swap? Is the flange for the housing not different on the 200sx? What about the downpipe - does this line up in the same place, or is the turbo further forward/back.
Rick.
Rick.
#50
Unknown.
Originally Posted by Hansenturbo
Brian, Or HansenTurbo
Who now sells them through Jamsport
Just he didnt want the Jamsport manifold, Which is yours... Obviously he didnt know
PS:
Are you making the 'over the gearbox' manifolds now for Jamsport too? Think Stuart has one? Or was that a one off?
Or just the normal one, As seen on MK's, Tom Scarlett's etc...
#52
from what i understand you will have too make a custom downpipe to bolt up too the 3 bolt cosworth turbo unit
#53
would the 200sx manifold pipes line up with the cvh head where the headers need welding on to them or does the tubes need moved/extended etc? good thread this
#54
Its a wicked idea but not as simple as first thought.
But if you could make them for 150-200 pounds then I think it would be well worth the effort.
The concept is easy I just think there will be a lot of try and error with getting the down pipe adapted to fit on to cosworth housing.
This is my conclusion of making one: -
Make a flange to the same size of a CVH head (copy a gasket)
Cut the old head flange off the 200sx
Weld the pipes to the new flange
Fit a Cosworth 3 bolt exhaust housing to the t34/t3
Then adapted the down pipe.
We need to confirm what turbo flange the 200sx has either a T25 or a T3
And how easy it is to change the standard down pipe.
Crazy cage please correct me where im wrong because I think you could be on to something here.
500 / 1100 quid is stupid money I no p/d work is second to none but on an RST its a joke.
Jim
Jim
#55
Custom
heres some better pics of the manifold on ebay
http://cgi.ebay.co.uk/NISSAN-200SX-S...em220074201323
http://cgi.ebay.co.uk/Nissan-200sx-s...em320054487257
#59
Stuart which one are you using?
And how much was it?
what did you do with your down pipe?
Cheers,
Jim
Cheers,
Jim
#60
mine but with external waste gate pipe underneath
u can get the down pipes from jamsport in 2.5 inch or in 3inch
2.5inch down pipe on the left, just needs weldin or clamping to the original exhaust
#62
PS:
#67
Jim
200 sx's are T25 exhaust housing.
#68
Originally Posted by crazycage
Originally Posted by turboben
and any pics in the bay to see how the turbo sits top work dude
#70
Originally Posted by Fiecos Dan
The turbo fitted to a 200sx is a t28,
but it uses a T25 exhaust housing and shaft, and a T3 comp side.
#71
200 sx's use a T25 flange.
So will need to be changed for a T3 flange.
#72
call me stupid but why not just use a t28 turbo with the manifold then all you have too do is make a flange too fit the cvh head just seems a bit easier
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
works out too about 500quid for manifold and a brand new ball bearing turbo
#75
focus rs 1672
Originally Posted by Rick
because the point of manifold is big power, more than the t28 will give.
#76
#78
Originally Posted by Tim
So do you all think a tubular manifold will reduce lag? because if you do you may be quite supprised.
Tim
Tim
#79
lets put it this way take a cossie engine with a 2 wd manifold which in reality is a cast tubular design,then take the same engine with a 4x4 manifold which is just a cast design manifold,the 4x4 1 is loads better and has less lag than the other unless you want 500 plus bhp when yes a tubular 1 of correct design will be better but will cause lots more lag.
I would like to see a fast car with a tubular manifold that works correctly the only 1 i have seen so far is nicks car from PF. and IMO the cost is way to high for the benifits.
Tim
Tim
