tubular exhaust for rst
#44
Originally Posted by Hansenturbo
Thanks guys
matt p: This customer wants to run a really big turbo so it has to get over the box
nthorpey: Yes m8 these manifolds is also going to made with zetec flange
as for the price duno yet
a little call to jamie soon me thinks
#45
Thanks guys
#46
Those manifolds look awesome, but sadly something i just couldnt afford.
Your showing those 200sx manifolds there, do you know how well the ports line up for say a zetec, just trying to find some manifolds for my conversion.
#50
Originally Posted by terreto
that is some job mate
where do you get the rocker covers with the nokia fones stuck to them
#51
Re: tubular exhaust for rst
i have made a new type of tubular manifold for rst what do you recon
is there any change in turbo response whith this long manifold ?
#52
#55
you do get what you pay for, but my mates just brought 1 for a skyline gts r33 that only cost him £220 the gain was about 40 hp on a bar of boost he still needs a fuel cut defender then its all the way to 480 for him
#56
Both of those maifolds look really nice. But how hard would it be to make one of these your self?? youd need the correct diameter stainless steel piping (various bends or bend your self) and a tig welder?? if im wrong, tell me
even if you had to make several to get the design right, once you have it yuo could then sell them for loads less than the crack smoking/selling $850
#57
#1 in Spelling Club
Trust me, it's not as easy as you make it sound.
#61
Tubular Manifold
I`m looking for a new manifold for my erst.. even thou this one looks awesome i dont want over the box..
Where can i get one from????
#62
Hi Brian, it looks amazing, just like the rest of your engine... if only my engine looked as tuff as yours
Må jeg iøvrigt være så fræk og spørge hvordan du får synet escorten med det setup... har selv lidt problemer med min JamSport motor ??
Henrik
Henrik
#66
Not being a prof engine tuner/builder...... but when making a tubular exhaust, are you not supposed to make sure the volume of each tube is the same ??
When i see the one from autospecialist and compare it to the one from HansenTurbo/JamSport, it looks like Autospecialist havent thought about equal lenghts in the tubes, or am i wrong ?
#67
Bodger of Blackburn
/\ spot on equal headers is the best thing to get good flow and spool.
the autospecialists one will be better than the cast rst one, due to the way the ports all meet up at the end, not cylinders 3 and 4 joining into each other at right angles and then join the other two which the standard one does
07-10-2015 12:56 PM
