should u
always get a bolt if u hold the coil lead ?
I have done in the past but wiv a diffrent car, not the RS.,, :eek:
:laughat: i bet that hurt :content:
:cry: :cry: :cry:
no it didnt give a bolt so i took the coil of another car and it fired stright up and just done a few miles all ok then took the coil wiych was on mine put it on the other and it didnt run but it still isnt givin a bolt
the coil is buggered then m8 it should give you a belt when i'ver running or turning its over and it fells like its pulling you fingers out :cry: :cry:
i no it was knacked but even the new 1 dos not give a bolt :roll:
ignition on thumb on the coil lead and other hand on chassis it might :cry:
ill give it a go :top:
© 2024 MH Sub I, LLC dba Internet Brands
