idle...
idle...
My S1 is idling really slowly as if its about to konk out...it fine when its cold but when the choke goes off it is idling veeeeery slowly.
How do I adjust it? Is there a screw somewhere?
It Wasnt Me!
If you look at the throttle body from the front, their is an idle adjustment screw on the right hand side, adjust to suit
Think you do it when the car has warmed up, might be wrong tho!
hi ive got a F reg series 2 and i had the same problam and it was the c0 level was low it was running to lean take it to your nearest mot centre and they will adjust it for you for about a fiver scott
Originally Posted by zippyobrien
just adjust the accelerator cable a lil bit,
on right of throttle body,
this is how i slowed mine down
The car should idle when cold at roughly the same RPM as when hot, if it starts to hunt and i quote "konk out" when its hot then you probably have an air leak somewhere, or mixture settings are low.
ZetecSX
73
28-05-2013 03:53 PM
ScORTED
13
16-07-2007 11:30 PM
