KE Jetronic ?
Custom
KE Jetronic ?
anyone know about the ke Jetronic system
like best plug leads to use etc info on the jetronic system i read somewhere that the fuel pressure goes down not up for enrichment
i know lots about efi but not alot about the mechanical ke
Custom
Rick
they dont seem to be cooling it down they switch on but the temp stays at the same level and they never go back off untill you switch engine off and let it cool down
Lee - they prob won't swith off. The std temperature switch is sensitive to impedence - basically different fans make it turn on and off at different temperatures. What does the temp gauge read?
Custom
when they come on its quite high about 10mm from the red i was going to change the fan switch but now your said that it don't sound like it is that have you got exactly the same fans as mine what temp does your fans come on ?
Ok, they should come on about half way, maybe a little over. With the std switch, mine used to do what urs do. I changed it to a variable thermostat, so now i can set it to come in wherever i want. Mine will go upto just over half at the very very most - but drops quickly as soon as u start moving.
Dont forget - upto 3/4 in heavy traffic is no problem - won't do any damage.
Shaunc
19-07-2015 05:16 AM
avatardrex
16-03-2011 06:42 PM
Garage19
28
04-11-2005 08:06 AM
