*GROUP BUY* MEF MOTORSPORT ADJUSTABLE TCA'S
Old 18-04-2006, 05:39 PM
  #201
akito-man
akito-man's Avatar
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
glad my payment went through
standard nite time dinners in disney for two adults and one kiddy,around 75 al in
thats not forgetting lunch and drinkypoos in the day.
Old 18-04-2006, 07:58 PM
  #202
Red16
Red16's Avatar
Originally Posted by NUTS RuS
No problem - how are they coming along ? Have you started them yet ??
will be starting them tonight at work
Originally Posted by andrek12345
what can you do with regards to rear suspention adjustment (mainly toe)
adjustable tie-bars?
dre
adjustable parallel arms will give you the toe in/out adjustment you require
MEF parallel arms
Old 18-04-2006, 08:14 PM
  #203
MEF
Former Sponsor
MEF's Avatar
Default Rear end adjustment
Yes, I do a pair of replacement adjustable tie bars, in-situ adjustable by having 2 rosejoints. 1 at either end, ie. 1 left hand and 1 right hand thread. Eliminates all rubber bushes, special link assembly goes in rear bottom Eye in place of those horrible bushes. Rear toe is adjustable like on the standard setup by shortening or lenghthening the tie bars (trailing arms) Watch out though, wont fit if using massively wide rear wheels with more inset, the tyre could catch on the trailing arm.
Ultimate setup is by replacing the rear wishbone by twin parallel bars but coil overs are then required.
See the website for details: www.mefmotorsport.com
Martin
Old 18-04-2006, 09:53 PM
  #204
akito-man
akito-man's Avatar
wow,the stuff you do is koolio
can you turn water into wine,whilst wheelieing a big bike?
dont the rose joints come in for a bit of a bashing on the trailing arms then,hence the need for bushes as standard,>?
and did you say the tie/trailing arms fit the standard pivot arms?
Old 18-04-2006, 10:02 PM
  #205
MEF
Former Sponsor
MEF's Avatar
Yes, I agree, the life expectancy of rose-joints is always going to be a lot less than rubber bushes. The ones I use are quite large (5/8 x 5/8) and rated at 16,000lbs loading so they can take some serious stick. In the grand scheme of things though, the cost of replacing them more often isn't that much when you consider the improvement they give and how much you spent on that engine!
Yes, the trailing arms (or rear tie rods as they are sometimes called) will fit straight on a bog standard car with NO other mods at the rear.
Martin
Old 18-04-2006, 10:10 PM
  #206
NUTS RuS
NUTS RuS's Avatar
Oy get turning some of that water into wine you....
Im thirsty
Old 18-04-2006, 10:13 PM
  #207
akito-man
akito-man's Avatar
here here
Old 18-04-2006, 10:14 PM
  #208
MEF
Former Sponsor
MEF's Avatar
Hmmmmmmmmmm, new project on the cards! The amount we go through here, that would be quite a saving! hic
Old 19-04-2006, 12:37 PM
  #209
Moonie
Moonie's Avatar
Just been and colected my adjustable TCAs, top quality!!
Martin, you have PM
Old 19-04-2006, 04:08 PM
  #210
Moonie
Moonie's Avatar
Originally Posted by MEFmotorsport
Yes, I agree, the life expectancy of rose-joints is always going to be a lot less than rubber bushes. The ones I use are quite large (5/8 x 5/8) and rated at 16,000lbs loading so they can take some serious stick. In the grand scheme of things though, the cost of replacing them more often isn't that much when you consider the improvement they give and how much you spent on that engine!Martin
Would you suggest using rubber boots to extend the life of the joint or could these trap dirt/water?
Old 19-04-2006, 07:04 PM
  #211
MEF
Former Sponsor
MEF's Avatar
Moonie,
Yes, I would recommend using a rubber boot on the rosejoint but also I think its a good idea to pack it with thick grease. I tried some rubber boots on some on my car once and as you say, they trapped water inside and actually caused corrosion, a liberal packing with grease might be the answer. You can get them from Rally Design.
Martin
Old 19-04-2006, 11:17 PM
  #212
Moonie
Moonie's Avatar
Ok, think im going to fit rubber boots to rosejoints and pack them with grease, try to extend the lifetime of the joint a little longer.
Just had a look on the rally design website at the boots, they are only a couple of £ so worth a go.
Old 20-04-2006, 10:14 AM
  #213
Drjones
Drjones's Avatar
MEFmotorsport
Has my payment turned up yet??
Old 20-04-2006, 11:57 AM
  #214
MEF
Former Sponsor
MEF's Avatar
DRJones:
Yes thanks, it arrived on Tuesday and went in the Bank yesterday.
I'll let you know when the TCA's are being sent but it wilnot be 'tilll next week now as they are currently under construction.
Cheers,
Martin
Old 20-04-2006, 02:31 PM
  #215
Drjones
Drjones's Avatar
thats fine m8 just wanted to make sure you got it
Old 20-04-2006, 04:32 PM
  #216
MEF
Former Sponsor
MEF's Avatar
Default payments update
1~Cawood confirmed-payment by transfer PAID/DELIVERED
2~Red16 paid by Paypal PAID DELIVERED
3~safechav
4~mathewwebber
5~danny boy
6~drjones PAID cheque
7~Hartyboy
8~rst dave paying by Paypal PAID/DELIVERED
9~John Laverick electronic transfer PAID/DELIVERED
10~little_hoss PAID cheque
11~Benn 304R
12~andyt
13~akito-man sending cheque, PAID
14~steve90spec confirmed, PAID
15~Moonie has confimed using paypal, PAID/DELIVERED
16~TeamFatboy Paypal, PAID
17~MJC PAID
18~Kirky PAID
19 ScortGTi PAID
20~Kay2 sending cheque
21~possibly S2man
Can those who showed an interest but have now dropped out please let me know for certain so I cancel them from the above list. This is not a problem, I just need to know exactly where I stand with numbers!
Thanks,
Martin
Old 20-04-2006, 04:57 PM
  #217
SafeChav
SafeChav's Avatar
Default Re: payments update
Thanks,
Martin
I still want mine, just had something arise, i take it as long as its reasonably soon it will be ok as you haven't finished making them anyway? Sorry for the delay i feel bad
Old 20-04-2006, 05:31 PM
  #218
NUTS RuS
NUTS RuS's Avatar
Im sure a small deposit will secure them
Old 20-04-2006, 05:55 PM
  #219
MEF
Former Sponsor
MEF's Avatar
OK, yes, If you send me a deposit, say £10, I will keep a pair aside at this "Group buy" price until you are ready, can't say fairer than that!
This applies to any others from the original list too. I'd judt like to delete those who were just dreaming!
Cheers,
Martin
Old 20-04-2006, 06:21 PM
  #220
SafeChav
SafeChav's Avatar
Thats fair enough then
U charge the extra % on paypal dont you?
Old 20-04-2006, 07:27 PM
  #221
dexterc
dexterc's Avatar
If anyone drops out, Id be willing to put a deposit down.
Old 20-04-2006, 07:41 PM
  #222
SafeChav
SafeChav's Avatar
Dexter i expect you can join in anyway its an April Group Buy price, PM him
Old 20-04-2006, 10:15 PM
  #223
MEF
Former Sponsor
MEF's Avatar
I am quite happy for any else to join in the group buy, the production line is up and running....slowly!
I dont charge any extra % for those using paypal, I just ask for enough to cover what they deduct, that amounts to about 4%, in this case £6.
Martin
Old 20-04-2006, 10:16 PM
  #224
SafeChav
SafeChav's Avatar
Thats what i meant by the %, the paypal fees which slowly are increasing more and more.
In that case if its ok with you i'll send a cheque?
Old 27-04-2006, 05:35 PM
  #225
akito-man
akito-man's Avatar
he must be busy banging away,
aye , and when hes finished that,then hell get on with them their adj tca,s
Old 01-05-2006, 05:02 PM
  #226
Drjones
Drjones's Avatar
Any news when there going to be posted mate?
Old 01-05-2006, 08:48 PM
  #227
NUTS RuS
NUTS RuS's Avatar
He'll be back online shortly, had to re-format his PC to get rid of a virus it thinks it picked up.
I do know he is just waiting on a couple of parts though Most of the cutting of the TCA's has been done, all the rose joints are in stock etc, as soon as the missing parts come in he'll be on the case
Old 01-05-2006, 11:23 PM
  #228
akito-man
akito-man's Avatar
drjones,
ive just removed the bushes from the pivot arms,ready for their first anti rust coat
Old 01-05-2006, 11:24 PM
  #229
SafeChav
SafeChav's Avatar
Originally Posted by akito-man
drjones,
what you going on about
Old 01-05-2006, 11:30 PM
  #230
akito-man
akito-man's Avatar
private convo, just some spares i have lying about,ready to be blinged.
Old 02-05-2006, 06:08 AM
  #231
MEF
Former Sponsor
MEF's Avatar
Default Group buy update
Hi folks......Sorry for the absence from the thread, as Tony said my PC got infected with spyware which resulted in a re-format etc
Anyway, back up and running now so here's the current situation:
The first 5 pairs were initially sent out as they were in stock already. I started building up a second batch of 5, the group buy has gone well beyond that now so have ordered extra parts for a third batch.
There are 2 problems, firstly a bad batch of 7/8UNF half nuts, I am waiting for the engineering company to supply replacements as the thread is cock-eyed, ie. they dont screw on straight!
Secondly I am also waiting on the engineering company to supply the "Forks" (for the 3rd batch) which is the part that gets welded onto the new TCA with the 7/8UNF stub on it.
I am hoping to get the nuts this week and expecting to be sending out the second batch of TCA's. I am away over next weekend in Belgium for the Monteberg rallysprint so I won't be around from early Friday am 'till late on Monday 8th so unfortunately I wont be getting any more done till after that.
Sorry about the above delays but it's out of my control and partly due to the incoming payments being initially very slow so very difficult for me to predict the scale of the group buy in the first place and hence how much money to invest in the parts up front if you see what I mean. This is not an excuse, just fact!
Thanks for being patient....
Martin
Old 02-05-2006, 06:32 PM
  #232
Drjones
Drjones's Avatar
no problem mate just wanted to make sure they had not been lost in the post or somthing
Thanks again
Old 02-05-2006, 06:54 PM
  #233
akito-man
akito-man's Avatar
wanted them yesterday
but spose thatll do,
only joking, yeah that should be fine.am i in the next batch ?
Old 03-05-2006, 10:55 PM
  #234
MEF
Former Sponsor
MEF's Avatar
Default Delivery update
OK, going on the courier tomorow 6 pairs:
Akito-man
MJC
DRJones
Little_hoss
Steve90spec
Kirky
Sorry if some are disappointed, deliveries are based in order of arrival of payment and/or persistant pushyness!
Cheers,
Martin
Old 04-05-2006, 01:38 PM
  #235
andyt
andyt's Avatar
Martin im still wanting mine mate
Old 04-05-2006, 03:32 PM
  #236
Danny boy
Danny boy's Avatar
when ever your ready mate mines still in paint for couple of weeks
Old 04-05-2006, 04:42 PM
  #237
Benn 304R
Benn 304R's Avatar
I still want mine, sorry I havent sent payment
Unfortunatly im having some problems at the mo so is it poss to give you a deposit and pay you end of the month or something?
Sorry for the hassle
Old 04-05-2006, 09:26 PM
  #238
akito-man
akito-man's Avatar
parsley (soup-herb!)
"so the policeman said!" "wots your name pal?"
mate said "van halliwell!"
copper said sarkily" right vanalliwell wots your second name smart arse?"
mate "no your the smart arse,ma name is VAN as is in morrison,HALLIWELL!"
oh how we chuckled just like the policemans mate!
Old 05-05-2006, 12:18 AM
  #239
NUTS RuS
NUTS RuS's Avatar
Benn 304R
That will be fine, Martin is away for the weekend now (rallying in Belgium) Just wait until next week he should be back by Tuesday. A deposit will hold them until your ready
Old 05-05-2006, 07:57 AM
  #240
Benn 304R
Benn 304R's Avatar
cheers Tony.
Quick Reply: *GROUP BUY* MEF MOTORSPORT ADJUSTABLE TCA'S
