Headlamp washer jets
Quick question, is it possible to get the jets out of the bumper without removing bumper itself? I have to adjust them a bit and I'm worried I will brake them, I would have to change them then and I wouldn't like to remove the bumper.
1 Post
they do ajust, push 2 small flat blade screwdrivers down the holes( one each side of teh tit in the middle) and rock back ward and forwards, they will eventually move with a creak then rock them about until u can rotate them to pint at the morretses,
even if you do so it's not a big job to remove the bumper...
but don't worry it should be fine
personnaly I found the answers to comply with the morrets I've add a seconde pump and a couple a jets, triggered the relay to control it via my water injection system and when it's hot outside I spray water outside the cooler in addition with the ISS
That I am not sure about. My can sdiffer form factory setup because of the bumper being fixed after the crash and then after former owner shit reparis of it. I'm pretyt sure it doesn't have all the factory mounts and that there is some other way it's attached to the body.
OK, sade it has been fixed this way
It's not the ssaddest thing about thepast of my Escos - check out my webside - you will know.
155lee
06-09-2016 11:10 AM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
155lee
24-10-2015 11:11 AM
DavidK
27-09-2015 02:55 PM
