RS500 cooler question??
thinking on buying one guys just wondered as i have air con how will it work?? cause i want the big cooler but i saw radtec do one with the air con in it do i have to do that??? or can i use the bigger one??
Originally Posted by Ryan_Belfast
Just throw out the aircon its what i have to do. you have windows and a sunroof, who needs aircon...
Well its not actually out of my car yet, but it will be either 2moro or the day after when i fit my rs500 intercooler, so you can buy it if you like.
I have brought a Pro alloy full kit rad,turbo cooler RS500 cooler and i have air con.
I have my car stipped and i have worked out you can fit it in but you need to cut the fron cross member a bit and make up some brakets. I have some photos but cant host them yet, but i have concerns on the hot air from the air con rad afecting the Inter cooler temps when you swich the air con on so i am going to do all the work to make it fit. But then i will run the car with out the air con rad in there check air temps then fit it but not swiched on and recorded the temps then switch the air con on and see how it likes it.
na i think as said air con is nice had it in my vr6 but uses more fuel and windows do that same job really so i think i'm gonna remove it, after all were in england boys!!! its raining most the time!!!
Nice one mate, definatly the best thing to do....ill be fitting mine in the next few days so if you want me to take pics and write down how to do it for you i will...
yer that be cool just too see how to remove the air con properly cheers ryan i should have a top fabrication company making me a nicey cooler up in a few weeks and a rad too so they may know neway but be nice to help them fit it anyway get it done quicker!!!
also wanna try and get my car bak up to that 300 bhp mark!!!!
GG himself supposed to be calling me this morning?? hopefully get things sorted so i can fit the pump and reg and then go get it setup with the chip put on....
almost impossible to check without removing the tank tho
anyway i have the new pump now so may aswell fit it
