running probs again
running probs again
the montes been running fine for the last 250 miles ,then tonight i was just going along at 30mph and it started to lose power again,just like before started to run rough /lumpy, i managed to keep it going and headed for home,a mile later it died on me,started up again but running really rough,managed to limp home another mile and took leads off one by one but it still ran the same[even with 2 leads off!]so doesnt seem ignition problem,any ideas before i defect?
Or regulator or blocked filter but it definitly sounds like a fuel prob!
Could you manage to fit a manometer on your fuel system?
Maybe by safety you could also check compressions and run an autodiag.
Not being funny but when my boost hose was hanging off the turbo mine fucked up exactly like that, check all the small dopey things like that.
syptoms sound exactly the same as when my crank sensor started packing up would be fine for ages then all of a sudden drove like crap, tested loads of stuff even chip, turned out it was a dodgey crank sensor after all of that
Eigdoog
13-09-2015 05:46 AM
