camshaft timing problem
Old 05-06-2019, 09:26 PM
xr400I
xr400I's Avatar
Default camshaft timing problem
After refitting head and putting camshafts back , the exhaust cam will not fit to the correct place ?
When the timing marks are lined up it would touch the valve on the piston. It would need to move another 20 degrees anticlockwise to align in the middle of the timing marks
Very confused?
The no 1 piston is at TDC and inlet is correct. The timing marks on the crank are aligned. Its a small turbo engine now fitted with a T38
It has been working for 20 years
Old 05-06-2019, 09:34 PM
james kiely
james kiely's Avatar
you sure your not 180 degrees out
Old 05-06-2019, 09:46 PM
xr400I
xr400I's Avatar
If the no 1 piston is at the top , Surely it must be right?
Old 05-06-2019, 10:01 PM
20/20 vision
20/20 vision's Avatar
Location: it's not where you are, it's where you've been and where you hope to be
is it possible that you have removed the woodruff key from the cam and fitted it back in the wrong slot in the cam? aftermarket cams are often made to be used as ex or inlet and thus have 2 slots.
as a very rough guide, when the engine is at tdc firing on #1 (and both valves are closed) if you look at the engine from the front of the car, #1 exhaust lobe should be pointing about 2 o'clock and and inlet should be pointing about 10 o'clock. neither lobe should be pushing down on the follower so the valve should not be anywhere near the piston
Old 05-06-2019, 10:02 PM
james kiely
1 and 3 will be at tdc.im just wondering is the cam in the proper position
Old 06-06-2019, 07:20 AM
xr400I
xr400I's Avatar
Woodruff Key in proper place and only single slot in cam
It is as thou the cam is 180 degrees out. It has Kent cams ca28 adjustable fitted and been working for 12 years
If you turn the exhaust 10 mm anticlockwise the valve hits the piston
Old 06-06-2019, 07:36 AM
Mark Shead
Mark Shead's Avatar
Your cams and not timed correctly. You look 180dg out.
Mark
Jan300 (06-06-2019)
Old 06-06-2019, 07:46 AM
xr400I
xr400I's Avatar
But How?
Old 06-06-2019, 07:48 AM
xr400I
xr400I's Avatar
Can the Kents be fitted on the wrong sides?
Old 06-06-2019, 08:06 PM
20/20 vision
you may have got the inlet and exhaust cams mixed up
Old 06-06-2019, 08:11 PM
xr400I
xr400I's Avatar
Solved
The scale showing the advance and retard is not the same position as the standard pulleys?
Its around 30 degrees off ??????
checked the position on the old cam and was obvious
Thanks for your suggestions
Old 06-06-2019, 08:22 PM
james kiely
happy days
john_d
22-07-2013 05:47 PM
Jumpinjacks
07-04-2012 09:33 PM
Thanasis
02-03-2011 10:34 AM
radiant red
18-10-2008 11:38 AM
garrett-killer
Ford Escort RS Cosworth
17-10-2007 06:04 PM
Quick Reply: camshaft timing problem
