YB Auxiliary Shaft "play"
Location: it's not where you are, it's where you've been and where you hope to be
i seem to recall that pinto shafts are a diff diameter to cossy ones - you aint bought the wrong one have you?
other possibility is a worn bearing in the block. a good one shouldn't have any play in the bearing which is oil fed otherwise you will likeley have very low crank oil pressure as oil will escape at this bearing
ltd500
12
25-10-2013 10:02 AM
B13 JUS
31-03-2005 07:05 PM
