Need some help on airbag
Hi , had the car sitting for a year and suddenly the airbag light in dash started flashing when the car is running, any help on what’s the problem please.
When you say it flashes - does it just flash on and off or does it stay on, or show a flash code?
On the newer Fords they show a flash code where there is a Wiki page listing all the results. (whether these codes are still relevant to an older car I don't know)
https://www.fordwiki.co.uk/index.php/Airbag_Flash_Codes
Most common on the older cars is a 4 flash code- is a seat belt pre-tensioner wiring fault.(If fitted) Either just clean the connectors under the seat or hard wire them.
(I have no idea what your car has as ref airbags, drivers,passengers etc.)
https://www.youtube.com/watch?v=mqr86mumYH8
the fault above may well be a failed wire in the clock spring
Steve
madmack99
19-09-2008 12:15 AM
McGoo 69
17-11-2007 05:38 PM
Charlie Chalk
06-09-2005 09:30 PM
