mapper needed for GRP A rally car
Old 24-10-2011, 03:42 PM
TMR
team markku rallying
TMR's Avatar
Default mapper needed for GRP A rally car
hi all i am in need of a good mapper for the escos rally car in or around yorkshire area. it is currently running on sunoco racing fuel for extra power and better cooling. i am looking to go back to standard fuel but worried about cooling, is there any other gadgets out there that help cooling.
Old 24-10-2011, 03:45 PM
BigErn
BigErn's Avatar
You could give Will Pedley a shout.
Old 24-10-2011, 03:50 PM
TMR
TMR's Avatar
where could i find contact details
Old 24-10-2011, 03:55 PM
BigErn
BigErn's Avatar
PM him on here fella..... or someone will be able to give you his number.
Old 24-10-2011, 04:33 PM
ian sibbert
ian sibbert's Avatar
In your area pal I'd try Nick Dixon @ MND motorsport - 07770 600310
Old 21-04-2012, 05:14 PM
TMR
TMR's Avatar
bit of a old thread but been realy busy i now have a pic of the ecu. has anyone and idea what limitations they have.
Old 21-04-2012, 05:48 PM
GVK.
GVK.'s Avatar
Level 8 ECU from late Cosworth 4x4 with lambda (green label)
Speak to MSD - http://www.motorsport-developments.co.uk/ or
Turbosystems https://passionford.com/forum/member...bosystems.html about tuning this.
Old 21-04-2012, 06:05 PM
TMR
TMR's Avatar
thanks, any idea on the limitations ie ALS launch duel maps etc
Old 21-04-2012, 06:24 PM
RS500/364
RS500/364's Avatar
would be worth the chat to grove and the trip north london would be 4 hours !
Old 21-04-2012, 06:34 PM
J1mbo
B1mbo
J1mbo's Avatar
Be very careful. Going back to pump fuel could bea bad move dependant on your engine spec, if it's late grp a or wrc compression then you may be out of luck.
Do you know what compression ratio your engine is?
For example, the wrc engines will det at 6psi of boost they run atmo sort of CR though
Old 21-04-2012, 06:38 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Jim talkes sense... so take note of his questions.
Info here on what we can do for your L8. Anything from an off the shelf program to a full on custom live map.
http://www.motorsport-developments.c...ecu_chips.html
Old 21-04-2012, 07:28 PM
TMR
TMR's Avatar
its not a wrc engine just uprated to grp a internals. pump fuel isnt a nessesaty just 200 quid for 50 ltrs is expensive on stage lol.
JoeyBoyden
04-01-2024 02:36 PM
matman
09-09-2015 05:45 PM
biggiejody
Insurance
02-09-2015 12:04 PM
col93saphcos
07-08-2015 03:21 PM
Quick Reply: mapper needed for GRP A rally car
