Heater not working!!!
Old 21-12-2004, 05:06 PM
K17SSE
K17SSE's Avatar
Default Heater not working!!!
Help!!!
My works van is of the road so i am having to use my kossie every day,
which is great BUT I HAVE NO HEATER
I have drained and refilled the coolant incase of airlock
I Have shoved a hose on the heater matrix to flush it out
The thermostat has not long since been changed
And the blower is working, the car gets to mid normal temp
What else can i check?????
Helps cos its damm cold!!!
PaulCR
Old 21-12-2004, 08:18 PM
Glenn5
Glenn5's Avatar
have you tried the bleed off cap on the top of the thermostat housing got 2 be worth a try
Old 21-12-2004, 08:42 PM
K17SSE
K17SSE's Avatar
not yet will give it a go know
PaulCR
Old 13-01-2005, 04:45 PM
foreigneRS
Testing the future
foreigneRS's Avatar
is the flap in the air distribution box moving when you turn the knob? maybe it's in the cold air position and the control cable has come off or slipped or something?
are the pipes going to and from the heater hot? if so, the matrix must be getting hot, but not getting any air over it.
Old 22-01-2005, 07:21 PM
MADsteveCOS
MADsteveCOS's Avatar
Check your cables, to the heater box, if they're intact then it's probably a buggered heater matrix, which all the cossies I've owned seem to suffer from when they're stored over the winter.
Hope that helps???
JK12
33
26-04-2021 12:09 PM
K42L
28-08-2015 01:23 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 06:54 PM
jimmy oldskool
04-08-2015 07:06 AM
Quick Reply: Heater not working!!!
