PassionFord - Ford Focus, Escort & RS Forum Discussion (https://passionford.com/forum/index.php)
-   Ford Escort RS Cosworth (https://passionford.com/forum/ford-escort-rs-cosworth-15/)
-   -   Wheel offset's (https://passionford.com/forum/ford-escort-rs-cosworth/266640-wheel-offsets.html)
vinnya77 Oct 29, 2008 12:47 PM
Wheel offset's
Does anyone know the offset needed for 8 x 18 wheels? Also is there any way of checking this? Thanks
Mike Rainbird Oct 29, 2008 12:59 PM
ET15 will give the best clearance of brakes and strut tops.
Lars_Ferm Oct 29, 2008 02:15 PM
i would go for around ET 10 it looks better and there are no problems.
vinnya77 Oct 30, 2008 07:15 PM
I have 8 x 18 OZ super T's with AP 6 pots underneath, and coil overs. I have no problems at all with my wheels. But I've been offered a 5th one as a spare, but the offset is ET20. I'm guessing this is going the wrong way size wise, from what you are saying.
Azrael Oct 30, 2008 07:39 PM
It all depends on the brakes and strut clearance. Standard wheel is 8'' and ET25 so I don't see why ET20 would be wrong, unless the brakes won't clear.
vinnya77 Oct 31, 2008 07:49 AM
Ok, thanks. I suppose, if it's ever needed, I can always put it on the back and move the back one forward if the puncture is up front.
Mike Rainbird Oct 31, 2008 08:16 AM
Super Ts were available in both ET20 and ET25, so you would need to check what you had. But either way, they will only accept 362mm brakes at best, and fit no bother. I know people who had the two different offsets on the car without even realising :cry:.
Azrael Oct 31, 2008 05:54 PM
Must have been great for handling...
© 2026 MH Sub I, LLC dba Internet Brands
