Escort Cossie uprated in tank pumps. Question
04-07-2008, 07:39 PM
What uprated in tank fuel pump are available and what power will the standard escort cossie tump support.
I have a 24V Sierra which i'm looking to get around 300bhp+ from. It has the intank fuel pump which i'm sure by the look of it is the same as the escort cossie one. Don't want to change to external pumps if i can help it. But if needs must i will.
Rob
04-07-2008, 07:49 PM
a bosch 003 or a 023 would do you.
i have one on my car and it was running 420-430, so well up to the job.
saying that....i have to get a swirl pot and a group A sierra one on mine aswell...more fuel needed for me.
04-07-2008, 07:51 PM
PassionFords Creator
Walbro ITP 048 if your going to make the power with sub 5.5bar fuel pressure.
For over 350bhp or to make power with over 5.5bar then i agree 100% with Dave. (023)
04-07-2008, 07:53 PM
Just hope there the same fitment now. Thanks
04-07-2008, 08:34 PM
Quote:
Originally Posted by
robrs2
well if you go for the bosch pump it will not be a straight fit anyway.
you will have to get a fitting kit off Mike R, then fit it in.
if you go for the Walbro one, then it will be a standard escort cos fitment.
i think your fitment will be the same as any Ford.
04-07-2008, 10:09 PM
04-07-2008, 10:17 PM
Almost there!
if you want to go for an 023 i have a spare sat here.
was in my car for about a year and now sat redundant.
let me know, but if you do want it id say half price of a normal brand knew one - then its just the fitting kit from Mike R.
04-07-2008, 10:26 PM
fitting kit not required!
05-07-2008, 09:55 AM
robbieg
it is for a bosch pump Robbie.
05-07-2008, 09:57 AM
dave cos4x4
Its not mate, i dont use one either.
05-07-2008, 09:58 AM
I had a 023 intank and it was fine until around 380atw then started to go lean as the pump maxed out.
05-07-2008, 10:01 AM
NEIL A
Sounds more like it was an 003?
05-07-2008, 11:01 AM
Engine Machinist
what power roughly should an 023 be able to fuel for?
05-07-2008, 05:43 PM
Did not know that Stu.
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
FlashRS
14-09-2015 12:36 PM
Billy_RS
15
05-09-2015 12:04 PM
Vincereese
18-08-2015 03:57 PM
stickyslick
14
10-08-2015 06:27 PM
