hi , does anyone knows who does convert the std p8 ecu to run 8 injectors and what mods do they make to the ecu?
many thanks mervin
I can do it through Pectel. Basically it turns the ECU into what is called "Super P8", and will have the following functions (some of which were already available on the normal P8):
1. DIS (coilpack)
2. Water injection
3. ALS
4. 8-injectors
5. 12-position boost control
This is done by adding an additional board to the ECU.
