ticking throttle sensor
Old 16-03-2008, 12:55 PM
cossie.con
cossie.con's Avatar
Unhappy ticking throttle sensor
hi guys i am very slowly getting my car ready for the road but keep hitting snags i have noticed now that the throttle sensor is clicking on ignition is this correct also when the car has run and i turn it off the cam pullys jump back a touch is this normal or what is the cause of this cheers for replys in advance
Old 16-03-2008, 03:40 PM
Dave Henshall
Dave Henshall's Avatar
the clicking when the ignition is on is the idle control valve, this is normal, shuold do it for about 10 secs then stop.
the pulleys, do you mean they turn backwards just as it stops - normal again, if its just coming up to a comprssion stroke it will be forced back to either just before top dead centre or bottom dead centre.
Old 16-03-2008, 03:49 PM
cossie.con
cossie.con's Avatar
thanks for the reply was a bit worried
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
mk3ste
17-10-2021 10:09 AM
Mark RS
12-10-2015 06:01 AM
Brickhouse
14
03-10-2015 07:28 PM
fordrallycar
30-09-2015 07:57 PM
Quick Reply: ticking throttle sensor
