Newbie question
Newbie question
How do all.
Im thinking of buying an escort cosworth and one of the ones im going to look at is supposed to be a 1996 big turbo model?????
Is this possible or will it be a small turbo thats been converted, the guy seems perfectly genuine i must say, its just i dont know a huge amount about cossies yet.
The car is purple ive been told so either jewel or aubergine if that helps.
What should i look for when i go to view it??
Also how troublesome are gearboxes and diffs ive heard different storys??
Thanks
Dave
Thanks
Dave
Rubber Rhino Crew
if its a st converted it's not the end of the world. the st is the best of the yb variants as it has the oil spray jets and other small differences that make is better than the older YBs.
Dan
Dan
Thanks mate is there anyway i can find out when im looking at it??
Are there any disadvantages or short cuts that can result from the conversion??
As i said the guy seems spot on ive no problem there and he has spent alot on the car so i know it should be in good nick.
Any advice on gear boxes and diffs what kinda power will they take??
Is a 96 jewel/aubergine a rare colour or not for resale value just to give me some haggling ammo??
Thanks again
Dave
Rubber Rhino Crew
http://www.grahamgoode.com/cosworth/power.htm
The main giveaway is the rocker cover....the link above shows both...top one is Big T (BT) and bottom one is ST.
The ST is known as the YBP and you'll find this stamped arround the thermostat housing area on the front of the engine....
There are many other ways to be sure...some of which i'm not 100% certain on so dont want to mis-inform you on them...someone else will provide info i'm sure.
dan
dan
Rubber Rhino Crew
The ST bottom end has piston spray jets as std does it not...
The cylinder head is different too but can't remember how tbh.
Also compared to the 2wd early engines there superior in most ways..and slightly better than the 4x4 bt lump so I think my statement stands up in court your honour
P.S. that fault code I spoke to you about on the phone was a boost solenoid reading error...fuck knows whats causing that but it'd going to vauxhall tomorrow to sort it out.
Dan
Dan
Rubber Rhino Crew
It's not a bad car overall and it drives really well but its drinking diesel (like 15-20mpg) at the minute and It's a mission to get to the garage every time as me and Bina both have long hours to work mon-fri...
I know for sure they're gonna drag heels over a turbo change; it only happens at about 80mph in 5th...it'll reset if ignitions left off for while but still comes back.
Dan
