£14k to spend
£14k to spend
Hey Cossie forum peeps...
Hey guys. Hopefully should have around £14k to spend on Cosworth. My plan is to keep it long term and ideally use it at weekends and on good weather etc.
In your honest opinions will £14k be enough to get a good standard (engine) car? - Obviously spending a large chunck of money on the car I want to get the right one.
Also I have a question, in standard form what's the more reliable engine out for the big turbo and small turbo? - I would imagine in standard guise the big turbo will be less stressed.
Also when leaving a car for lengthy periods is there anything i should be aware of?
Muchos thanks
Matt.
Muchos thanks
Matt.
£14K should get you a good standard car, nothing in it between the BT & ST in standard form on the reliability front. A lot depends on how well the car has been looked after. The BT can be better power wise because of the standard turbos size compared to the ST & gives scope for cheap power, but the ST is a better everday car I'd say.
Depends on what you call long periods. Some don't like being left for a week others can go months. Just one of those things I guess. Mine stays on the drive all year round & gets started / driven every week. Not seen a problem like some have that posted on here after being left in the garage over winter.
i got mine almost a year to the day.... its a st.. one, its the first winter for me, and i have not got much use
out off it this winter / well the odd day .. but its been fine for me so far...... good luck on find the right one for you.....
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
dojj
28
11-09-2015 10:00 PM
