front drive shaft inner gaiter
has anybody got correct finnis for above?
ive got 2 from microcat 6672258 inner 6672257 outer got both from ford nothing like originals. |
they are difficult to find
go to a local motor factor and ask for the inner gaitor from a sierra 4x4, don't matter which one or engine size as they are all the same gaitors if you tkae the old one in with you it'll be possible to match as some will give you the outer one, even though it's the correct part number on the box |
go to a local motor factor and ask for the inner gaitor from a sierra 4x4, don't matter which one or engine size as they are all the same gaitors if you tkae the old one in with you it'll be possible to match as some will give you the outer one, even though it's the correct part number on the box thanks |
i got mine from fords recently
when i did mine a couple of yrs back it took about 3 attempts before fords got me the correct ones :cry: they kept insisting they were right even though they werent :cry:
the ford inner ones are now different, they are now made by another supplier & don't have the neck like the old ones.
great, even more confusion :cry: :cry: :cry:
they look like all outers to me
yes inner ones are solid to find :( ... my shafts problems on tha side were me due to finding out recon shafts were being fitted with new boots and the boots aren't big enough ie not got enough stretch in them so was constantly pulling the big end of the boot off and fcuking the joint i went through 3 shats to find this out :wall: ... the only option available is to use a long boot and instead of clamping the small end where it should, clamp it the other side of the ridge and it will never pull the boot off ;)
bit of a cheat works very well just a shame they dont make the proper sized ones anymore :bat: Ad |
© 2024 MH Sub I, LLC dba Internet Brands
