geometry
Old Dec 16, 2007 | 09:34 AM
garrett-killer's Avatar
garrett-killer
Default geometry
hi!
i searched,but couldn´t find good results.
i´ve got koni with eibach springs on my escos
and 18" rondell,
whats the best geometry (toe in,castor,camber)
on the front and on the rear !
best regards chris
Old Dec 16, 2007 | 01:44 PM
Azrael's Avatar
Azrael
Best for what? There are as many geometry setups as there are conditions, purposes, driving styles. It is also a matter of compromise between stability, cornering balance, cornering speed, turn-in and tyre longevity.
On road car it's even harder to find good compromise.
Also what kind of adjustments are possible on you r car? Anything above standard front toe?
Old Dec 16, 2007 | 05:08 PM
garrett-killer
thank you mate!
most road use,sometime tracks.
it´s a stock car,polybushed alround
i have adjusted
toe and camber on my turbo fiesta
rearbeam with washers,works fine,
but i need the best camber degrees
and toe for road use.
best regards chris
Old Dec 16, 2007 | 05:53 PM
Azrael's Avatar
Azrael
I think 2,5 degrees forn and 2 degrees rear camber works well on Escos on road tyre, mybe a little less, you'd realli need to experiment a little because it's very much suspension/tyre dependant. I have never driven an Escos on 18's.
Old Dec 25, 2007 | 03:24 PM
Fiecos Dan's Avatar
Fiecos Dan
to give you a rough idea,
For road
Front,
1.5 road, To 2.5' track neg camber
3-4 castor
Rear,
1 - 1.5 neg camber
Old Dec 25, 2007 | 04:00 PM
garrett-killer
thank you very much!
but how much toe?
is it better toe in or out on a 4wd cossi?
best regards chris
Old Dec 25, 2007 | 05:06 PM
Fiecos Dan's Avatar
Fiecos Dan
i run 1mm toe in on rear, and 1mm toe out on front.
Old Dec 25, 2007 | 08:13 PM
ECOS95's Avatar
ECOS95
I'm sure its 0.5mm toe in on the front which is ideal. There meant to run parallel, but people set them to toe in so they pull straight when accelerating.
Old Dec 25, 2007 | 09:19 PM
garrett-killer
thank you guys!
i will try ~ 0 toe front and ~1mm toe on the rear
could someone explain why
some cars need toe out on the front
and toe in the rear?
chris
Old Dec 25, 2007 | 11:46 PM
Fiecos Dan's Avatar
Fiecos Dan
i set my xr2t with toe out, so when it accelerate's it pulls straight.
just look up how i last set my cossie up. (2 years ago) Road / trackday / sprint car.
Front,
1mm toe in, 2' camber, (castor wasnt adjustable at time @ 1')
Rear, on shimmed std beam.
2mm toe in, 1' camber
Avo coilovers, 450lb front springs, 240lb rears.
With 1220kg trackday wieght, no driver and 1/4 fuel,
2430 wheel base, 1652mm track width Front +Rear.
My Xr2tt runs
15" zetec s wheels on 195/45/15 Goodyear F1's for road and wet track, Dunlop slicks for dry track.
- Gaz front coilovers, 300lb springs, -50mm front, -60mm and spax adj rear, poly bushed.
-Fronts, 4' castor, 2.5' camber, 2mm toe in for track, 0.5' camber, 1mm toe out for sprints and road.
-Rears, 0.5' camber, 1mm toe out. (solid beam, but will make fully adjustable if i get it back on the road)
Old Dec 26, 2007 | 08:31 AM
garrett-killer
thank you,
i try your settings tomorrow!
wow,very impressive,
you run 300lb springs on a 900kg car?
and 450lb on a 1200kg car?
they aren´t good for street driving or?
could you describe the handling on streets?
best regards chris
Old Dec 26, 2007 | 09:00 AM
Fiecos Dan's Avatar
Fiecos Dan
Cossie =
1365kg in road trim inc full fuel tank, and driver (i wiegh 85kg's)
as trackday trim = 1305kg, full fuel and driver
Xr2 =
as on road 1035kg (inc me at 85kg), 1/4 tank of fuel, with tools,spare and stuff.
Track trim = 985kg with me.
they are both fine on the road, but i'm willing to sacrefice (sp) ride for track performance.
on the track i use road legal tyres on the cossie and full slicks on the xr2.
Old Dec 27, 2007 | 12:37 AM
ossie cossie's Avatar
ossie cossie
landaqmabba
Sep 15, 2015 07:16 PM
Mike1
Apr 3, 2009 11:34 AM
sbyford
Feb 27, 2007 10:57 PM
DaveEscos
Oct 29, 2005 12:42 AM
Neil S
20
Aug 11, 2004 08:41 AM
