Hubs converter ??
ya cant use hub adaptors to go from 4 to 5 stud i'm afraid , one stud will always be mis-aligned...
best way to go about it is to carry out a ford granada hub conversion , then use adaptor plates from there on in to achieve the PCD you require.
You can have the holes welded in the 4 stud hubs and get the re-drilled for the 5 stud pattern.
Not sure if it possible to just re-drill the 5 stud holes and leave the others still there.
