Bleeding Brakes....
Old 09-05-2007, 07:23 PM
Rolls
Rolls's Avatar
Default Bleeding Brakes....
Hi guys -
what have you founf to be the best way?
Front, then backs with the ignition on? - there have been some posts saying to do the backs first....
cheers
Old 09-05-2007, 08:31 PM
- Sim -
- Sim -'s Avatar
depends on what you did before
normally you say:
the caliper that is farthest away of your brake fluid reservoir at first, then the other side of the back.
after that the front side which is farther away from the brake fluid reservoir and then the last caliper which is on the brake fluids reservoir.
no ignition needed for that.
We did it that way several times and it worked out perfect.
hope you understand what i wanted to tell you
for a german escort cosworth, the brake fluid reservoir is on the drivers (left) side this would mean:
1. rear right
2. rear left
3. front right
4. front left
Old 09-05-2007, 08:40 PM
Kelv
Almost there!
Kelv's Avatar
As Sim has said, start at the furthest caliper away from the brake resevoir and work your way forward.
have heard people mention that you leave the ignition on the first click.
Old 10-05-2007, 03:02 AM
Arnie
Arnie's Avatar
still need to bleed the rear one when just changing the front ?
Old 20-05-2007, 09:24 PM
phill295
phill295's Avatar
how does leaving the ignition on help with bleeding the brakes
Old 21-05-2007, 07:54 AM
dojj
Resident Wrestling Legend
dojj's Avatar
the rear brakes work when you have the ignition on and press the pedal to open the valve and let the pump pressureise the rear cuirit
if you've got your foot on the pedal you open the belld nipple and the fluid comes out in a contant stream so none of this pumping the pedal malarky
you can fill and drain most of the fluid in teh system just by doing this which elaves a lot less for you do to on the fronts (the rear lines anr shared and split just near the rear axle so do both erars and then do the front with the normla pressing of the pedal stuff)
others have said ther are other ways to do it but this is the way i've been doing it for the past 14 years and never had a problem
just make sure you dno't get an air lock in the abs valve block, as these are a right pain in the arse to get rid of
Chas
05-10-2015 07:13 PM
kevin36
09-09-2015 11:12 AM
markk
09-09-2015 08:11 AM
kevin36
08-09-2015 12:23 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Bleeding Brakes....
