ECU help please, identification
hi peeps, well i bought my car a month or so back, and the lad i got it off said it would need setting up, its running grey injectors, rs500 intercooler, uprated T34, uprated fuel pump, uprated actuactor grp a head gasket, these are all i can think off at the minute. But he said the car was running collins software
the problem is i am booked into MSD in blackpool for them to have a play with it, but i have the ecu out and open to have a look wat was in, and i found this:
could someone please identify wat ecu this is and roughly wat chip it might be
any help would be appreciated
STU is a top top man IMO, he certainly knows his stuff, and tells you straight.
Be prepared for a big smile when he sorts your car, the difference between a superchip and a live map from him is night and day.
Originally Posted by topham
cheers mate
anybody else identify the chip?
if not with wat i am running now, could i run an evo chip??340 bhp
That chip has 403 on it which is either grey or blue injectors (can't remember).
Injectors in order of size starting from smallest first.
Standard and stage 1 is yellow (2wd) and blues (4x4).
Stage 2 is light greens (no longer used).
Stage 3 is dark greens (MSD's stage 2).
Light blues.
Greys.
Blacks 55lb.
Blacks 83lb.
Light blues.
Greys.
Blacks 55lb.
Blacks 83lb.
argh right i see
best just letting him have a play
i found this website
www.powerchips.co.uk
this is direct to collins so it could well be a colins chip afterall
thanks peeps
thanks peeps
DixieTheKid
14-09-2015 09:04 PM
