turbo gaskets
26-04-2007, 09:39 AM
turbo gaskets
just removed heat shield on big turbo cosworth and looks like i have water leak from water pipe that goes into bottom of turbo is there a gasket for it and also is there washers available for the 2 larger bolts on the side of the housing and where would i get them from. thanks for any help
26-04-2007, 12:49 PM
Washers for the banjo bolts, just get from ford matey!
Don't have a clue about the gasket - soz!
26-04-2007, 03:57 PM
bottom one will be oil return, there is a small fibre gasket fitted to it, water ones are on each side
26-04-2007, 08:44 PM
RSBryden
06-09-2015 08:39 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
cozzzzy power
04-09-2015 08:14 AM
turbowag
03-09-2015 08:07 AM
Jerry Ryan
02-09-2015 08:02 PM
