front tca's & rear camber
Old 23-04-2007, 07:52 PM
GUZZLER
GUZZLER's Avatar
Default front tca's & rear camber
going to change the front tca's on my car soon, the car is only lowered on a koni adjustable kit, is it worth fitting adjustable tca's??? The camber is not to bad on the front but the back camber gets a bit excessive when the kids are i the back & theres a bit of gear in the boot, is there an easy way round the rear camber or is it best to just fit an aftermarket beam.
Old 23-04-2007, 08:05 PM
Kelv
Almost there!
Kelv's Avatar
you can fit 10 thou shims at the back edge of the rear hubs, between the hub and the trailing arm to aid the angles when it squats.
but to be honest the only 'real' cure is to invest in a rear beam
SmudgerByName
52
28-07-2016 06:14 PM
155lee
14
22-08-2015 12:15 PM
C2 MAK
20-08-2015 09:46 PM
dal3door
13-08-2015 06:55 AM
track.focus'd
12-08-2015 05:53 PM
Quick Reply: front tca's & rear camber
