Removing a Escos Steering Rack ?? ITS OUT !!!
Post Miester !
I have to take the steering rack out the Escos Sunday,
I presume its similar to my sapph cossie,anyone knwo of any
tricky bits to remove ??
Ta...
Ta...
Originally Posted by THE RADMAN
hardest part is getting the mounting bolts o ut,esp if you have aircon
There is a procedure to remove and install it, if you get this right its pretty straighforward (i'll try to dig it out), i also remember the alternator had to come off as you can't pull one of the rack retaining bolts out far enough to get the rack out !!
Originally Posted by the youth
I have just done mine and it has air con...lets just say I hope the new rack never ever has to come out again!!!
the bracket for the air con compressor onto the block was the worst to undo, access was a nightmare especially the rear bolt
Steve
Steve
Ad
I found the job dead easy, done twice now. Get the car well up and supported. Very easy. No air con on mine mind. But done a lot worse jobs.
I don't know what the sub frame talk is all about
Alternator doesn't have to come off just jack the engine up a bit till bolt comes out.
Chris
Steve
Steve
Ad
steve
There is normally a reason bolts are fitted the way they are.
(not just to annoy us)
fitted from the top down.......Should the nut ever come off then the bolt is not going to fall out and you will not lose your steering.
Fitted from the bottom up what do you think will happen to the bolts???? heaven forbid if the nuts ever came off, and then the rack would be held in by what
Well if you do what I have done and fit nyloc's aswell as drill the bolt and put a split pin through it...... Nothing probably.....
There is also a reason why these cars dont run over 300 brake from the factory but we arent bothered about a little thing such possibly melting the engine are we
Rally cars run an inverted bolt, my car is REGULARLY inspected, MORE than most cars on the road IMO... if the bolt is working loose I will know
Post Miester !
Got the bugger out today !!
Was not too bad, just needs hands of a five year old ..lol..
Got carried away the whole engine bay is in bit now
Off to the powder coaters tomorrow
rsguy
44
29-09-2015 03:29 PM
